GMA.1B.045.DB
GMA.1B.045.DB
    LEMO(雷莫)
    GMA.1B.045.DB
GMA.1B.045.DB 数据手册
GMA.1B.045.DB www.lemo.com SUMMARY # Wires Image is for illustrative purpose only Series 1B Termination type No contacts / Accessory IP rating 0 AWG wire size 0.00 - 0.00 Cable Ø 4.50 - 4.90 mm Status active Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model GMA*: Bend relief White Keying No keying Housing Material Brass (gold plated [ISO 27874]) shell, collet nut, brass latch sleeve and mid pieces Variant B : White Weight .85 g Performance Configuration Insulator Rated Current Others Temp (min / max): -40°C / +80°C LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/2 DRAWINGS Dimensions A L mm. 4.5 30 in. 0,18 1,18 RECOMMENDED BY LEMO Tools LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/2
GMA.1B.045.DB 价格&库存
很抱歉,暂时无法提供与“GMA.1B.045.DB”相匹配的价格&库存,您可以联系我们找货
GMA.1B.045.DB
    • 1+51.117271+6.63988
