GMA.1B.040.DG
GMA.1B.040.DG
    LEMO(雷莫)
    GMA.1B.040.DG
GMA.1B.040.DG 数据手册
GMA.1B.040.DG www.lemo.com SUMMARY # Wires Image is for illustrative purpose only Series 1B Termination type No contacts / Accessory IP rating 0 AWG wire size 0.00 - 0.00 Cable Ø 4.00 - 4.40 mm Status active Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model GMA*: Bend relief Grey Keying No keying Housing Material Brass (gold plated [ISO 27874]) shell, collet nut, brass latch sleeve and mid pieces Variant G : Gray Weight .89 g Performance Configuration Insulator G: PEEK/Pehd Rated Current Others Temp (min / max): -40°C / +80°C LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/2 DRAWINGS Dimensions A L mm. 4.0 30 in. 0,16 1,18 RECOMMENDED BY LEMO Tools LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/2
GMA.1B.040.DG 价格&库存
很抱歉,暂时无法提供与“GMA.1B.040.DG”相匹配的价格&库存,您可以联系我们找货
GMA.1B.040.DG
    • 1+35.201661+4.53098
    • 10+33.9684310+4.37225
    • 25+31.7401725+4.08544
    • 50+29.7841150+3.83366
    • 100+28.05760100+3.61144
    库存:199
