GMA.2B.060.DB
GMA.2B.060.DB
    LEMO(雷莫)
    BEND RELIEF 6.0MM WHITE
GMA.2B.060.DB 数据手册
GMA.2B.060.DB www.lemo.com SUMMARY # Wires Image is for illustrative purpose only Series 2B Termination type No contacts / Accessory IP rating 0 AWG wire size 0.00 - 0.00 Cable Ø 6.00 - 6.50 mm Status active Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model GMA*: Bend relief White Keying 2 keys (alpha=30, plug: male contacts, receptacle: female contacts) Housing Material Brass (gold plated [ISO 27874]) shell, collet nut, brass latch sleeve and mid pieces Variant B : White Weight 1.73 g Performance Configuration Insulator Rated Current Others Temp (min / max): -40°C / +80°C LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/2 DRAWINGS Dimensions A L mm. 6.0 36 in. 0,24 1,42 RECOMMENDED BY LEMO Tools LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/2
GMA.2B.060.DB 价格&库存
很抱歉,暂时无法提供与“GMA.2B.060.DB”相匹配的价格&库存,您可以联系我们找货
