GMA.3B.090.DG
GMA.3B.090.DG
    LEMO(雷莫)
    GMA.3B.090.DG
GMA.3B.090.DG 数据手册
GMA.3B.090.DG www.lemo.com SUMMARY # Wires Image is for illustrative purpose only Series 3B Termination type No contacts / Accessory IP rating 0 AWG wire size 0.00 - 0.00 Cable Ø 9.00 - 10.00 mm Status active Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model GMA*: Bend relief Grey Keying No keying Housing Material Brass (gold plated [ISO 27874]) shell, collet nut, brass latch sleeve and mid pieces Variant G : Gray Weight 2.75 g Performance Configuration Insulator G: PEEK/Pehd Rated Current Others Temp (min / max): -40°C / +80°C LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/2 DRAWINGS Dimensions A L mm. 9.0 42 in. 0,35 1,65 RECOMMENDED BY LEMO Tools LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/2
GMA.3B.090.DG
1. 物料型号:型号为EL817,是一款光隔离型光电晶体管。
2. 器件简介:EL817是一种光隔离型光电晶体管,具有高输入阻抗和低输出阻抗,适用于高速光耦合器。
3. 引脚分配:EL817有3个引脚,分别为阳极、阴极和发射极。
4. 参数特性:主要参数包括最大正向电流150mA,最大反向电压5V,最小正向电压1.0V。
5. 功能详解:EL817通过光电效应实现电信号的传输,具有隔离作用,可应用于数字信号传输。
6. 应用信息:EL817广泛应用于数字通信、测量设备、工业控制系统等领域。
7. 封装信息:EL817采用DIP-6封装,尺寸为9.1mm3.6mm3.3mm。
GMA.3B.090.DG 价格&库存
很抱歉,暂时无法提供与“GMA.3B.090.DG”相匹配的价格&库存,您可以联系我们找货
