GMA.2B.045.RG
GMA.2B.045.RG
    LEMO(雷莫)
    GMA.2B.045.RG
GMA.2B.045.RG 数据手册
GMA.2B.045.RG www.lemo.com SUMMARY # Wires Image is for illustrative purpose only Series 2B Termination type No contacts / Accessory IP rating 0 AWG wire size 0.00 - 0.00 Cable Ø 4.50 - 5.00 mm Status active Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model GMA*: Bend relief Grey Keying 2 keys (alpha=30, plug: male contacts, receptacle: female contacts) Housing Material PPSU (Polyphenylsulfone, creme)shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Variant G : Gray Weight 1.65 g Performance Configuration Insulator G: PEEK/Pehd Rated Current Others Temp (min / max): -60°C / +200°C Temperature range in water steam: +140°C LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/2 DRAWINGS Dimensions A L mm. 4.5 41 in. 0,18 1,61 RECOMMENDED BY LEMO Tools LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/2
GMA.2B.045.RG 价格&库存
很抱歉,暂时无法提供与“GMA.2B.045.RG”相匹配的价格&库存,您可以联系我们找货
