FLEX
RELIEF
HANDLE
AAAHZ SHOWN
CONNECTOR
QT3MZ SHOWN
3 PIN
AAA3MZ
SHOWN
AAA
6 PIN
7 PIN
CONTACT PINS AS VIEWED FACING MALE CONNECTOR
M
2.69±0.12
E
68.2±3.05
SMALLER CABLES
SHORTEN ASSEMBLY
Z
SERIES:
Q-G CONNECTOR
SEE TABLE FOR
FLEX RELIEF SIZE
0.71
18.0
FLAT
# OF CONTACT PINS:
3, 4, 5, 6, OR 7
GENDER:
MALE
0.65
16.4
FLAT
0.75
18.9
HANDLE STYLE:
BLANK - METAL HANDLE (SEE FINISH BELOW)
P - PLASTIC HANDLE, BLACK
FINISH:
BLANK - NICKEL HANDLE & CONNECTOR,
WITH BLACK FLEX RELIEF & GREEN INSERT
B - BLACK HANDLE & CONNECTOR,
WITH BLACK FLEX RELIEF & BLACK INSERT
W - WHITE HANDLE & NICKEL FINISH CONNECTOR
WITH WHITE FLEX RELIEF & GREEN INSERT
5 PIN
4 PIN
0.78
19.7
1.99
50.6
F
CONTACT PIN PLATING:
BLANK - SILVER
AU - GOLD
FLEX RELIEF STYLE:
BLANK - FLEX RELIEF I.D. 0.135 [3.4mm]
RECOMMENDED CABLE O.D. 0.100 - 0.220 [2.5mm - 5.6mm]
L - FLEX RELIEF I.D. 0.225 [5.7mm]
RECOMMENDED CABLE O.D. 0.220 - 0.285 [5.6mm - 7.2mm]
0.55
14.0
E
CUSTOMER DRAWING
NOTES:
1. CONNECTORS AND HANDLES ARE SHIPPED SIDE BY SIDE OR IN BULK.
2. MATERIALS:
HANDLE METAL - ZINC ALLOY, NICKEL PLATED OR BLACK OR WHITE PAINTED.
E HANDLE PLASTIC - THERMOPLASTIC, BLACK
CABLE CLAMP - THERMOPLASTIC, BLACK
FLEX RELIEF - THERMOPLASTIC, BLACK OR WHITE.
HOUSING - ZINC ALLOY, NICKEL PLATED OR BLACK SATIN CHROME PLATED
INSULATOR - THERMOPLASTIC, GREEN OR BLACK
GROUND TERMINAL - SPECIAL COPPER ALLOY
CONTACT PINS - COPPER ALLOY, SILVER PLATED OR GOLD PLATED
3. THESE PRODUCTS ARE RoHS COMPLIANT.
THIS DRAWING DESCRIBES A DESIGN CONSIDERED PROPRIETARY IN NATURE, DEVELOPED AND MANUFACTURED
BY SWITCHCRAFT INC. AND IS RELEASED ON A CONFIDENTIAL BASIS FOR IDENTIFICATION PURPOSES ONLY.
STAR SYMBOL DENOTES CRITICAL DIMENSION
F
27473
03/27/15
PC
TJK
UNLESS OTHERWISE SPECIFIED
1. ALL DIMENSIONS IN INCHES
- TWO PLACE DECIMALS
0.01
- THREE PLACE DECIMALS
0.005
- ANGLES
1
- ALL DIA. CONCENTRIC WITHIN 0.005 T.I.R.
E
27081
01/25/13
D
25711
10-17-07 JGK
C
24940
3-11-05
JL
TJK
B
24552
10-13-03
JL
BRH
2. FEATURES ON THE SAME CENTERLINE
MUST BE ALIGNED WITHIN 0.002
A
24446
8-12-03
JL
BRH
3. REMOVE ALL BURRS
REV
ECO NUMBER
DATE
REVISIONS
BL
TJK
BY
TJK
APVD
DO NOT SCALE DRAWING
SolidWorks CAD File
SIZE
WIDTH
MULT
FINISH
03-10-03
NAME
BY
BRH
SPEC No.
SCALE
1.5:1
CHKD
BRH
8-12-03
APVD
BRH
8-12-03
MALE XLR CONNECTOR, RoHS
B
TEMPER
MATERIAL
SPEC No.
FIRST USED ON
DATE DRAWN
LBS/M
SHEET
PART No.
1
OF
AAA_MZ SERIES
1
REV
F
很抱歉,暂时无法提供与“AAAHPZ”相匹配的价格&库存,您可以联系我们找货
