HR34B-12WR-C
HR34B-12WR-C
    HRS(广濑)
    CONNCAPRCPTSZ12STRAPWTRPRF
HR34B-12WR-C 数据手册
Push-on Bayonet Lock Miniature Waterproof Connectors HR34B Series Push-on Bayonet Lock Mating : Just inserting plug unit will complete mating Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Un-mating : Rotating sleeve to unlock mating fig.1 ■Features Cable exit directions 1. Water and dust protection • IP67 or more (IP68) water and dust protection rating when fully mated. • Resistant to industrial grade oils. • 4-position receptacles are sealed against water penetration when mounted on the panel - no protective cap is required. 2. Easy and precise mating • Mating: Just inserting plug unit completes mating Unmating: Rotating sleeve counterclockwise unlocks connectors (fig.1) • Marking helps align plug with receptacle when mating. • 3 guide keys make blind mating possible. (Receptacle structure prevents plug from damaging receptacle terminals) fig.2 3. Multi-directional cable exit Right angle plugs allow the cable to exit in 8 directions, in 45˚ increments.(fig.2) 4. Safty standards ¨ The 4-position connectors meet requirements of TUV standard. 5. Wide variation Item Number of positions Connector type Terminations(plug) Terminations(receptacle) Conduit material Applicable cable size(Reference) 4,10 straight plug,right angle plug,receptacle solder,crimp wire solder plastic,metal (Ø5.7~6.5), (Ø6.5~7.3), (Ø8.0~9.0) 2020.96 1 HR34B Series●Push-on Bayonet Lock Miniature Waterproof Connectors ■Product Specifications Current rating 10 pos. : 3A 4 pos. : 5A Operating temperature range -20°C to 125°C Voltage rating 10 pos. : 200V AC, 250V DC 4 pos. : 200V AC, 200V DC (Pollution degree 3) 400V AC, 400V DC (Pollution degree 2) Storage temperature range -10°C to 60°C Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Ratings Item 1.Contact resistance 2.Insulation resistance 20mø max. 1,000Mø min. Specification Conditions 1A DC 500V DC 10 pos. : 900V AC / 1 minute 4 pos. : 2,000V AC / 1 minute 3.Withstanding voltage No flashover or insulation breakdown 4.Vibration No electrical discontinuity of 10μs or longer Frequency : 10 to 500 Hz/cycle, total amplitude of 0.75 mm, 98m/s2 each, 3 hours in 3 axis. 5.Shock No electrical discontinuity of 10μs or longer Acceleration of 490 m/s2, 11 ms duration, 3 axis, each for 3 hours 6.Durability (Mating / un-mating) Contact resistance : 30mø max. 500 cycles 7.Temperature cycle Insulation resistance : 500Mø min. Temperature : -55°C / +15° to +35°C / +85°C / +15° to +35°C Time :-30 min. / 2 to 3 min. / 30 min. / 2 to 3 min. 5 cycles 8.Humidity Insulation resistance : 50Mø min. (at high humidity) Insulation resistance : 500Mø min. (when dry) 336 hours at 71°C, and humidity of 95% 9.Water protection No water penetration inside connector At the depth of 1meters for 0.5 hours. ■Materials / Finish ●Plugs Part Outer shell Insulator Female contacts 10 pos. 4 pos. O-ring Gasket Material Finish Remarks Zinc alloy, aluminum alloy, and polyamide resin (black) Black chrome plating, black chromate finish (Trivalent Chromium) --------------- Color : Black Gold plated Silver plated UL94V-0 ----------------------------- --------------- --------------- PPS Phosphor bronze Copper alloy Fluororubber, Nitrile hydride rubber ●Receptacles Part Material Outer shell Zinc alloy Insulator Male contacts Ground contact O-ring 2 10 pos. 4 pos. 4 pos. PPS Copper alloy Brass Brass Fluororubber Finish Black chromate finish (Trivalent Chromium) Color : Black Gold plated Silver plated Silver plated --------------- Remarks --------------UL94V-0 --------------------------------------------------------- HR34B Series●Push-on Bayonet Lock Miniature Waterproof Connectors ■Product Number Structure ●Plugs HR34B - 12 WP A - 10 S - X ( ** ) 1 2 3 4 5 6 8 5 Number of contacts. 1 Series name 2 Shell size 3 Shell style : HR34B Series : Diameter(mm) of the mating interface of the plug WP : Straight plug WLP : Right-angle plug 4 Conduit material and Applicable cable size A : Conduit material metal, Applicable cable (Reference) : (Ø5.7~6.5) B : Conduit material metal, Applicable cable (Reference) : (Ø6.5~7.3) D : Conduit material plastic, Applicable cable (Reference) : (Ø5.7~6.5) E : Conduit material plastic, Applicable cable (Reference) : (Ø6.5~7.3) K : Conduit material metal, Applicable cable (Reference) : (Ø8.0~9.0) Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 7 (Excluding ground contacts) 6 Contact type S : Female, wire solder SC : Female, crimp 7 Keying Blank : Standard X : X key position Other specifications : 2 numerical digits wil be added when 8 there is a specifications change other than shown in positions q to u ●Receptacles HR34B - 12 WR A - 10 P - X ( ** ) 1 1 2 3 4 2 3 4 5 Series name : HR34B Series Shell size : Diameter(mm) of the mating interface of the plug Shell style WR : Receptacle Shell type A : Square flange for 10 positions B : Square flange for 4 positions 6 7 8 5 Number of contacts. (Excluding ground contacts) 6 Contact type P : Male,wire solder 7 Keying Blank : Standard X : X key position 8 Other specifications : 2 numerical digits wil be added when there is a specification change other than shown in positions q to u ●Crimp contacts HR34B - SC1 - 2 1 1 1 2 1 Series name : HR34B Series 2 Contact style : SC1 : Female contact 3 Contact type 3 4 5 4 Conductor size : 20 to 25AWG 5 Plating 1 : Gold plated 1 : 100pcs/pack 2 : 10,000pcs/reel 3 HR34B Series●Push-on Bayonet Lock Miniature Waterproof Connectors ■Straight plugs ●Standard type (Conduit material :Plastic) A Ø19 49 ◆Wire solder All dimensions : mm Part No. Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. HRS No. A Applicable cable diameter range(Reference) HR34B-12WPD-10S 134-0026-0 00 Ø7.4 (Ø5.7~6.5) HR34B-12WPE-10S 134-0027-2 00 Ø8.5 (Ø6.5~7.3) HR34B-12WPD-4S 134-0020-3 00 Ø7.4 (Ø5.7~6.5) HR34B-12WPD-4S-X 134-0023-1 00 HR34B-12WPE-4S 134-0025-7 00 Ø8.5 (Ø6.5~7.3) HR34B-12WPE-4S-X 134-0031-0 00 HRS No. A Applicable cable diameter range(Reference) HR34B-12WPD-10SC 134-0037-6 00 Ø7.4 (Ø5.7~6.5) HR34B-12WPE-10SC 134-0038-9 00 Ø8.5 (Ø6.5~7.3) HRS No. A Applicable cable diameter range(Reference) HR34B-12WPA-10S(71) 134-0004-7 71 Ø7.4 (Ø5.7~6.5) HR34B-12WPB-10S(71) 134-0007-5 71 Ø8.5 (Ø6.5~7.3) HR34B-12WPK-10S 134-0052-0 00 Ø9.5 (Ø8.0~9.0) HRS No. A Applicable cable diameter range(Reference) HR34B-12WPA-10SC 134-0017-9 00 Ø7.4 (Ø5.7~6.5) HR34B-12WPB-10SC 134-0028-5 00 Ø8.5 (Ø6.5~7.3) HR34B-12WPK-10SC 134-0053-2 00 Ø9.5 (Ø8.0~9.0) Solder cup inner diameter Ø1 Ø1.7 ◆Crimp (separate contacts required) Part No. ●Robust type(Conduit material :Metal) ◆Wire solder All dimensions : mm Part No. Solder cup inner diameter Ø1 ◆Crimp (separate contacts required) Part No. Not all cables of applicable dia. range can be easily assembled. Please kindly check with factory before use. BIllustrations of mated connectors. Straight plug Mating combinations B 4 B 10 pos.plug + receptacle wire solder 50.1 4 pos.plug + receptacle wire solder 49.6 HR34B Series●Push-on Bayonet Lock Miniature Waterproof Connectors ■Right angle plugs ●Standard type (Conduit material : Plastic) B 33.5 A Ø19 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ◆Wire solder All dimensions : mm HRS No. A HR34B-12WLPD-10S Part No. 134-0039-1 00 Ø7.4 (Ø5.7~6.5) HR34B-12WLPE-10S 134-0040-0 00 Ø8.5 (Ø6.5~7.3) HR34B-12WLPD-4S 134-0030-7 00 HR34B-12WLPD-4S-X 134-0034-8 00 HR34B-12WLPE-4S 134-0035-0 00 HR34B-12WLPE-4S-X 134-0036-3 00 Ø7.4 B Applicable cable diameter range(Reference) 30.85 Solder cup inner diameter Ø1 (Ø5.7~6.5) Ø1.7 Ø8.5 (Ø6.5~7.3) ◆Crimp (separate contacts required) Part No. HRS No. A HR34B-12WLPD-10SC 134-0041-3 00 Ø7.4 HR34B-12WLPE-10SC 134-0042-6 00 Ø8.5 B Applicable cable diameter range(Reference) (Ø5.7~6.5) 30.85 (Ø6.5~7.3) ●Robust type (Conduit material :Metal) ◆Wire solder All dimensions : mm Part No. HRS No. A B Applicable cable diameter range(Reference) HR34B-12WLPA-10S(71) 134-0005-0 71 Ø7.4 HR34B-12WLPB-10S(71) 134-0008-8 71 Ø8.5 HR34B-12WLPK-10S 134-0054-5 00 Ø9.5 31.5 (Ø8.0~9.0) HRS No. A B Applicable cable diameter range(Reference) HR34B-12WLPA-10SC 134-0018-1 00 Ø7.4 HR34B-12WLPB-10SC 134-0029-8 00 Ø8.5 HR34B-12WLPK-10SC 134-0055-8 00 Ø9.5 Solder cup inner diameter (Ø5.7~6.5) 30.5 (Ø6.5~7.3) Ø1 ◆Crimp (separate contacts required) Part No. 30.5 31.5 (Ø5.7~6.5) (Ø6.5~7.3) (Ø8.0~9.0) Not all cables of applicable dia. range can be easily assembled. Please kindly check with factory before use. BIllustrations of mated connectors. Right-angle plug Mating Combinations A (33.5) 10 pos. plug shell A,B type. Plug + receptacle wire solder 31.0 10 pos. plug shell D,E type. Plug + receptacle wire solder 31.3 10 pos. plug shell K type. Plug + receptacle wire solder 32.0 4 pos. plug + receptacle wire solder 31.3 A 5 HR34B Series●Push-on Bayonet Lock Miniature Waterproof Connectors ■Receptacles ◆Wire solder 48) 2. (R 3.2 4-Ø 1 3 8 10 B A 4 7 A B All dimensions : mm Part No. Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. HRS No. A B Solder cup inner diameter HR34B-12WRA-10P 134-0016-6 00 17.26 23.4 Ø1 HR34B-12WRB-4P 134-0021-6 00 18.26 25.4 Ø1.4 HR34B-12WRB-4P-X 134-0024-4 00 O ring for water proof is not attached. Please find appropriate one from the market. BRecommended panel cutouts ●Receptacle - wire solder All dimensions : mm 4-B HR34B-12WRA-10P HR34B-12WRB-4P HR34B-12WRB-4P-X 17.26±0.05 18.26±0.05 A A B A M3∞0.5 C 1 0/-0.1 1.1 0/-0.1 D 12.5 +0.1/0 16.3 +0.1/0 E 17 +0.1/0 20.8 +0.1/0 C Recommended O ring dia. Part No. HR34B-12WRA-10P ØD HR34B-12WRB-4P ØE HR34B-12WRB-4P-X Thickness Inner diameter Ø1.5 Ø11.5 Ø1.5 Ø15.5 BReceptacle Contact Arrangement 4 pos.wire solder 10 pos.wire solder note.1 View direction : Mating surface note.2 mark is ground terminal. 1 2 1 4 3 8 BCrimp contacts 2 5 3 6 9 7 10 15 1.2 ◆Female Part No. HRS No. Applicable conductor 20 to 25AWG (Stranded wire) HR34B-SC1-111 134-0051-7 00 100 pcs/pack HR34B-SC1-211 134-0050-4 00 10,000 pcs/reel Note : Use wire with a jacket diameter of 1.7mm max. 6 Packaging HR34B Series●Push-on Bayonet Lock Miniature Waterproof Connectors BConnector Mating Combinations 10 pos. Plugs 10 pos. Receptacles Straight, Wire Solder or Crimp HR34B-12WPA-10S(71),10SC HR34B-12WPB-10S(71),10SC HR34B-12WPD-10S,10SC HR34B-12WPE-10S,10SC HR34B-12WPK-10S,10SC Wire Solder HR34B-12WRA-10P Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Right angle, Wire Solder or Crimp HR34B-12WLPA-10S(71),10SC HR34B-12WLPB-10S(71),10SC HR34B-12WLPD-10S,10SC HR34B-12WLPE-10S,10SC HR34B-12WLPK-10S,10SC 4 pos. Plugs 4 pos. Receptacles Straight, Wire Solder (Standard key position) HR34B-12WPD-4S HR34B-12WPE-4S Standard key position Wire solder (Standard key position) HR34B-12WRB-4P Right angle, Wire Solder (Standard key position) HR34B-12WLPD-4S HR34B-12WLPE-4S Standard key position Straight, Wire Solder (X key position) HR34B-12WPD-4S-X HR34B-12WPE-4S-X Wire solder (X key position) HR34B-12WRB-4P-X Right angle, Wire Solder (X key position) HR34B-12WLPD-4S-X HR34B-12WLPE-4S-X X key position X key position 7 HR34B Series●Push-on Bayonet Lock Miniature Waterproof Connectors BApplicable tools Type Automatic Crimping Machine Body Automatic Crimping Machine Applicator Part No. CM-105C AP105-HR34B-1 HRS No. 901-0001-0 901-2051-2 Applicable Cable Manual Crimp Tool HT304/HR34B-1 150-0107-9 UL20276 20 AWG,23 AWG,25 AWG HR34B-SC1-111 Terminal Extraction Tool RP6-SC-TP 150-0039-0 ―――― HR34B-SC1-111 HR34B-SC1-211 ―――― 20 AWG to 25 AWG Applicable Contact ―――― HR34B-SC1-211 Note 1 : Perform crimping based on the "Crimping Quality Standards" and "Crimping Conditions Table" Note 2 : Problems that occur when using tools not designated by Hirose are outside the scope of warranty. Note 3 : The applicable cables and applicable contacts are limited to those listed in the above table. For inquiries on cables not listed contact a Hirose representative. Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ◆Manual contact crimping tool ◆Press CM-105C (Applicator ◆Contact extraction tool ordered separate) BHandling 1. Mating 2. Un-mating Plug Receptacle B A Rotate counter-clockwise Mating position alignment marks Holding the plug by the outer shell (A) align the arrow on the plug with the alignment mark on the receptacle and push straight in. BPrecautions Rotate the sleeve (B) counter-clockwise to a full stop and un-mate the plug from the receptacle. Center line of the connector Alignment mark When completely mated and locked the alignment arrow on the plug must line-up with the center line of the connector (alignment mark on the receptacle). If the alignment arrow and the center line of the connectors are not aligned (1mm max.) re-insert the plug until they are aligned. 1 mm max. 1. When disconnecting or inserting the connector, be sure to do so after turning off the power. 2. To insert the connector, push it in until the arrow tip of the plug mating mark indicates the specified position of the diagram below (i.e., the mating mark of the receptacle). 3. Note that the display method of the mating mark will differ depending on the receptacle. 4. To maintain the waterproof quality and cable clamp force, use a cable that is within the range of the applicable cable diameter. 5. Please consult Hirose Electric Sales for harness assembly procedure (ETAD-C0116-00). 6. Please note that the white label on the connector may come off due to solvents such as alcohol. ® 8 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN TEL: +81-45-620-3526 Fax: +81-45-591-3726 http://www.hirose.com http://www.hirose-connectors.com The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 09/2020. Contents are subject to change without notice for the purpose of improvements.
HR34B-12WR-C 价格&库存
很抱歉,暂时无法提供与“HR34B-12WR-C”相匹配的价格&库存,您可以联系我们找货
