AAAHBZ
AAAHBZ
    SWITCHCRAFT
    CONN HANDLE AAA BLACK
AAAHBZ 数据手册
FLEX RELIEF HANDLE AAAHZ SHOWN CONNECTOR QT3MZ SHOWN 3 PIN AAA3MZ SHOWN AAA 6 PIN 7 PIN CONTACT PINS AS VIEWED FACING MALE CONNECTOR M 2.69±0.12 E 68.2±3.05 SMALLER CABLES SHORTEN ASSEMBLY Z SERIES: Q-G CONNECTOR SEE TABLE FOR FLEX RELIEF SIZE 0.71 18.0 FLAT # OF CONTACT PINS: 3, 4, 5, 6, OR 7 GENDER: MALE 0.65 16.4 FLAT 0.75 18.9 HANDLE STYLE: BLANK - METAL HANDLE (SEE FINISH BELOW) P - PLASTIC HANDLE, BLACK FINISH: BLANK - NICKEL HANDLE & CONNECTOR, WITH BLACK FLEX RELIEF & GREEN INSERT B - BLACK HANDLE & CONNECTOR, WITH BLACK FLEX RELIEF & BLACK INSERT W - WHITE HANDLE & NICKEL FINISH CONNECTOR WITH WHITE FLEX RELIEF & GREEN INSERT 5 PIN 4 PIN 0.78 19.7 1.99 50.6 F CONTACT PIN PLATING: BLANK - SILVER AU - GOLD FLEX RELIEF STYLE: BLANK - FLEX RELIEF I.D. 0.135 [3.4mm] RECOMMENDED CABLE O.D. 0.100 - 0.220 [2.5mm - 5.6mm] L - FLEX RELIEF I.D. 0.225 [5.7mm] RECOMMENDED CABLE O.D. 0.220 - 0.285 [5.6mm - 7.2mm] 0.55 14.0 E CUSTOMER DRAWING NOTES: 1. CONNECTORS AND HANDLES ARE SHIPPED SIDE BY SIDE OR IN BULK. 2. MATERIALS: HANDLE METAL - ZINC ALLOY, NICKEL PLATED OR BLACK OR WHITE PAINTED. E HANDLE PLASTIC - THERMOPLASTIC, BLACK CABLE CLAMP - THERMOPLASTIC, BLACK FLEX RELIEF - THERMOPLASTIC, BLACK OR WHITE. HOUSING - ZINC ALLOY, NICKEL PLATED OR BLACK SATIN CHROME PLATED INSULATOR - THERMOPLASTIC, GREEN OR BLACK GROUND TERMINAL - SPECIAL COPPER ALLOY CONTACT PINS - COPPER ALLOY, SILVER PLATED OR GOLD PLATED 3. THESE PRODUCTS ARE RoHS COMPLIANT. THIS DRAWING DESCRIBES A DESIGN CONSIDERED PROPRIETARY IN NATURE, DEVELOPED AND MANUFACTURED BY SWITCHCRAFT INC. AND IS RELEASED ON A CONFIDENTIAL BASIS FOR IDENTIFICATION PURPOSES ONLY. STAR SYMBOL DENOTES CRITICAL DIMENSION F 27473 03/27/15 PC TJK UNLESS OTHERWISE SPECIFIED 1. ALL DIMENSIONS IN INCHES - TWO PLACE DECIMALS 0.01 - THREE PLACE DECIMALS 0.005 - ANGLES 1 - ALL DIA. CONCENTRIC WITHIN 0.005 T.I.R. E 27081 01/25/13 D 25711 10-17-07 JGK C 24940 3-11-05 JL TJK B 24552 10-13-03 JL BRH 2. FEATURES ON THE SAME CENTERLINE MUST BE ALIGNED WITHIN 0.002 A 24446 8-12-03 JL BRH 3. REMOVE ALL BURRS REV ECO NUMBER DATE REVISIONS BL TJK BY TJK APVD DO NOT SCALE DRAWING SolidWorks CAD File SIZE WIDTH MULT FINISH 03-10-03 NAME BY BRH SPEC No. SCALE 1.5:1 CHKD BRH 8-12-03 APVD BRH 8-12-03 MALE XLR CONNECTOR, RoHS B TEMPER MATERIAL SPEC No. FIRST USED ON DATE DRAWN LBS/M SHEET PART No. 1 OF AAA_MZ SERIES 1 REV F
AAAHBZ 价格&库存
很抱歉,暂时无法提供与“AAAHBZ”相匹配的价格&库存,您可以联系我们找货
