FGG.00.735.DN
FGG.00.735.DN
    LEMO(雷莫)
    FGG.00.735.DN
FGG.00.735.DN 数据手册
CONNECTOR SELECTION GUIDE Precision modular connectors to suit your application Since it’s creation in Switzerland in 1946 the LEMO Group has been recognized as a global leader of circular Push-Pull connectors and connecting solutions. Today LEMO and its affiliated companies, REDEL and COELVER, are active in more than 80 countries with the help of over 40 local partners. This vast portfolio enables you to select the ideal connector configuration to suit almost any specific requirement in most markets, including medical devices, test and measurement instruments, machinery, audio video broadcast, telecommunications and military. LEMO has set connector standards, such as the 3K.93C connector for HDTV and the 00.250 connector for NIM.CAMAC. Custom design and cable assembly Over 50’000 connector combinations The modular design of the LEMO range provides over 50’000 combinations of connectors from miniature ø 2 mm to ø 50 mm, capable of handling cable diameters up to 30 mm and for up to 114 contacts. LEMO offers the most extensive product line, but some applications require a unique design. LEMO can supply a connecting solution that meets your specific requirements, including special materials, personalized layout and cable assembly. Some good reasons to choose a LEMO connector Extensive product range: The modular design and extensive range of Lemo connectors enables you to select the ideal connector for your application. EMC protection: the metallic outer shell offers screen efficiency superior to that of standard screened cables and most other connectors. Reliability: due to the high quality of their design and manufacture, LEMO connectors usually last as long as the equipment. Long-term availability: LEMO guarantees to supply your connector, however specific, over a very long period of time since most LEMO connectors are produced with standard components. Ruggedness: Suitable for use in high vibration and shock environments. Aesthetics: the attractive high tech design of LEMO connectors enhances any front panel design and contributes significantly to the appearance of your product. Local LEMO team: your best support Selecting the right connector for any project is an important and sometimes challenging process. LEMO offers dedicated professional support to help you choose the best suitable solution. LEMO invites you to call our local partner for technical support. LEMO Push-Pull self-latching system 1. This self-latching system is renowned worldwide for its easy and quick mating and unmating features. It provides absolute security against vibration, shock or pull on the cable. 2. The LEMO self-latching system allows the connector to be mated by simply pushing the plug axially into the socket. 3. Once firmly latched, connection cannot be broken by pulling on the cable or any other component part other than the outer shell release sleeve. 4. When required, the connector is disengaged by a single axial pull on the outer shell release sleeve. This first disengages the latches and then withdraws the plug from the socket. Standard range K Series E Series 2C/2G Series Series Contact Configurations Description S Series Standard self-latching multipole connectors with alignment key. The original standard self-latching connectors with stepped inserts for alignment (of multipole version). Watertight self-latching multipole connectors with alignment key and rugged housing for extreme working conditions. Watertight self-latching connectors with stepped inserts for alignment (of multipole version) and rugged housing for extreme working conditions. Short self-latching multipole connector with key (2G series) or stepped inserts alignment (2C series). • Multipole 2 to 64 contacts • Multi or mixed contacts with: Coaxial 1 to 14 contacts Fluidic 1 to 14 contacts High voltage 2 to 21 contacts Fibre optic 1 to 14 contacts • Thermocouple 2 to 64 contacts • Fibre optic • Fluidic • • • • • • Unipole Coaxial 50 and 75 Ω Multipole 2 to 106 contacts Triaxial 50 and 75 Ω High voltage Multi or mixed contacts with: Coaxial 1 to 8 contacts High voltage 2 to 8 contacts • Thermocouple 2 to 6 contacts • Multipole 2 to 64 contacts • Multi or mixed contacts with: Coaxial 1 to 14 contacts Fluidic 1 to 14 contacts High voltage 1 to 21 contacts Fibre optic 1 to 14 contacts • Fibre optic • Thermocouple 2 to 64 contacts • • • • • • Unipole Coaxial 50 and 75 Ω Multipole 2 to 106 contacts Triaxial 50 and 75 Ω High voltage Multi or mixed contacts with: Coaxial 1 to 8 contacts High voltage 1 to 8 contacts • Thermocouple 2 to 6 contacts • Multipole 18 contacts (2G series) • Multipole 2 to 14 contacts • Coaxial 50 Ω (2C series) Main Features B Series • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • Push-Pull self-latching 8 sizes 13 keying options 9 colour codings Over 60 shell styles UL recognized Temp. range -55°C to 250°C Solder, crimp or print contacts Shielding: > 75dB at 10Mhz > 40dB at 1 Ghz • IP50 • For cable ø 1 to 25 mm Push-Pull self-latching 8 sizes Multipole with stepped inserts 9 colour codings Over 50 shell styles UL recognized Temp. range -55°C to 250°C Solder or print contacts Shielding: > 75dB at 10Mhz > 40dB at 1 Ghz • IP50 • For cable ø 1 to 30 mm Push-Pull self-latching 6 sizes 9 keying options Over 28 shell styles UL recognized Temp. range -55°C to 200°C Solder, crimp or print contacts Shielding: > 95dB at 10Mhz > 80dB at 1 Ghz • IP66 / IP68 • For cable ø 1 to 23.5 mm Push-Pull self-latching 7 sizes Multipole with stepped inserts Over 22 shell styles UL recognized Temp. range -55°C to 200°C Solder or print contacts Shielding: > 95dB at 10Mhz > 80dB at 1 Ghz • IP66 / IP68 • For cable ø 1 to 30 mm Push-Pull self-latching 9 colour codings Over 13 shell styles (2C series) Temp. range -55°C to 250°C Solder or print contacts • IP50 • For cable ø 1.7 to 7.9 mm Military (harsh environment) Other F Series Series Contact Configurations Description Watertight self-latching connectors with alignment key, stepped inserts and rugged housing for extreme working conditions. Compact self-latching multipole connectors, with multiple alignment keys, for harsh environment. Ratchet screw system enables quick and secure coupling of the connectors. Connectors for harsh environment with multiple alignment keys. Genderless connectors with patented push-pull hermaphroditic self-latching system. Self-latching connectors with 4 concentric contacts. • Multipole 2 to 10 contacts • Thermocouple 2 to 6 contacts • Multipole 2 to 68 contacts • Multi or mixed contacts with: Fibre optic 2 contacts Other mixed versions upon request • Multipole 2 to 114 contacts • Multipole 6 or 12 contacts • Multi or mixed contacts with: Fibre optic 2, 4 or 6 contacts • Quadrax (4 concentric contacts) Main Features H Series L Series • • • • • • • Push-Pull self-latching 3 sizes Stepped inserts 5 keying options Over 20 shell styles Temp. range -55°C to 200°C Shielding: > 95dB at 10Mhz > 80dB at 1 Ghz • Solder or print contacts • • • • • • • • • • • • • • • • • • • • Ratchet coupling mechanism 6 keying options Compact and lightweight Oil and fuel resistant 12 shell styles Temp. range -50°C to 200°C Shielded Crimp or print contacts High vibration resistance (gunfire test) • High shock resistance • Optional anti-vibration flange fixing • Dark finish • • • • • • • • • • • • • • • IP66 / IP68 • For cable ø 1 to 10.5 mm • IP67 • For cable ø 2 to 34 mm • IP68 • For cable ø 2 to 27 mm • IP50 / IP68 • For cable ø 3.6 to 10 mm Push-Pull self-latching 8 sizes 4 keying options Compact and lightweight Over 12 shell styles Temp. range -50°C to 200°C Shielded Crimp or print contacts High vibration resistance High shock resistance Dark finish M Series Push-Pull self-latching 2 sizes Hermaphroditic blind mating Lightweight Over 4 shell styles Temp. range -55°C to 125°C Solder or crimp contacts Dark finish Aluminium alloy shell 1D Series Push-Pull self-latching 8 colour coding Over 7 shell styles Temp. range -40°C to 120°C Shielding: > 70dB at 10Mhz > 35dB at 1 Ghz • Solder contacts • IP50 • For cable ø 3 to 7.5 mm Plastic 00 Series 01 Series 0A Series Series Contact Configurations Description REDEL® P Series Rectangular self-latching connectors with plastic shell. Self-latching plastic connectors with alignment key for medical applications. Coaxial 50 Ω self-latching connectors, the basis of the NIM-CAMAC standard. Smallest self-latching coaxial 50 Ω connectors. Coaxial self-latching connectors for video or telecommunication applications. • Multipole 10 to 65 contacts • Mixed contacts with: Coaxial 1 to 8 contacts Fluidic 1 to 8 contacts High voltage 1 to 8 contacts • • • • • Coaxial 50 Ω • Triaxial • Coaxial 50 Ω • Coaxial 50 or 75 Ω Main Features R Series Miniature • • • • • • • • • Push-Pull self-latching • 3 sizes • Several keying options • 6 colour codings • Over 12 shell styles • Temp. range -50°C to 170°C • IP 64/66 options • White, gray or black outershell • • • • Push-Pull self-latching Over 40 shell styles Temp. range -55°C to 250°C Shielding: > 90dB at 10Mhz > 70dB at 1 Ghz • Solder or crimp contacts • • • • • • • • • • • • IP50 • For cable ø 2.7 to 9.5 mm • IP50 • For cable ø 1.5 to 5 mm • IP50 • For cable ø 1.8 to 2.8 mm Push-Pull self-latching 3 sizes 2 keying options Available in 4 colours 5 shell styles Temp. range -30°C to 150°C Compact and lightweight Solder, crimp or print contacts • IP50 • For cable ø 1 to 9.2 mm Multipole 2 to 34 contacts Voltage mains Fluidic Mixed contacts in 2P and 3P series with: Coaxial 1 contact High voltage 1 contact Fibre optic 1 contact Fluidic 1 or 3 contacts Push-Pull self-latching Over 15 shell styles Temp. range -55°C to 230°C Shielded Solder or print contacts • IP50 • For cable ø 2.5 to 6.3 mm High voltage 5G Series REDEL® K/S Series REDEL® D Series Series Contact Configurations Description 05 Series Other Single contact self-latching high voltage connector with a test voltage from 5 to 70 kV d.c. Miniature single contact high voltage self-latching connector with a test voltage of 12kV d.c. Compact and lightweight high voltage self-latching connector in multicontact version with alignment key and test voltage of 12kV d.c. Multi high voltage rectangular connectors for research applications. Smallest snap-on subminiature fibre optic connector. • Single HV contact • Single HV contact • Multi HV 50 contacts • Multi high voltage K series with 22 contacts S series with 51 contacts • Fibre optic single channel Main Features Y Series Push-Pull self-latching Over 27 shell styles Temp. range -55°C to 250°C Shielded Solder or crimp contacts Working frequency up to 3 Ghz @ 75 Ω • Push-Pull self-latching • Test voltage from 5 to 70kV d.c. • 3 sizes • Temp. range -55°C to 250°C • Solder contacts • Optional safety locking device • Push-Pull self-latching • Test voltage of 12kV d.c. • Over 2 shell styles • Temp. range -20°C to 125°C • Safety locking device • Crimp contacts • Aluminium alloy shell • Push-Pull self-latching • Test voltage of 12kV d.c. • Over 2 shell styles • 2 keying options • Temp. range -20°C to 125°C • Safety locking device • Crimp contacts • Aluminium alloy shell • Compact design • • • • • • • • • • • • IP50 • For cable ø 1 to 29 mm • IP50 • For cable ø 1.1 to 3.3 mm • IP50 • For cable ø 4.5 to 16.5 mm Self-latching fastener Test voltage 12kV D.C. Crimp contacts Keying Temp. range -20°C to 125°C Snap-on fastening Sub-miniature size Low mass Mating endurance up to 30 cycles Ceramic floating ferrule 1.25 mm For singlemode and multimode fibres • For cable ø 0.25 to 0.9 mm Audio-Video 4M Series 3K.93C Series REDEL® F Series Series Contact Configurations Description 4A Series Watertight self-latching coaxial and triaxial connectors for TV camera applications. Waterprotected self-latching triaxial connectors for TV camera applications. (US standard.) Watertight self-latching triaxial connectors with alignment key for TV camera applications (UK standard). Hybrid electrical-fibre optic self-latching connector for HDTV applications (SMPTE / ARIB / EBU Standard). Waterprotected self-latching triaxial connectors for TV camera applications. • Coaxial 75 Ω • Triaxial 75 Ω • Triaxial 75 Ω • Triaxial 50 and 75 Ω • Hybrid with: 2 fibre optic contacts 2 signal contacts 2 power contacts and ground • Triaxial 75 Ω Main Features 3T Series • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • Push-Pull self-latching Over 7 shell styles Temp. range -55°C to 200°C Shielded Intermatable with ULC series size III • IP66 • For cable ø 8.5 to 17.5 mm Push-Pull self-latching Over 10 shell styles Temp. range -55°C to 200°C Shielded Intermatable with Kings TRI-LOC KP80.. series • IP61 • For cable ø 8 to 14.5 mm Push-Pull self-latching Keying Over 10 shell styles Temp. range -55°C to 200°C Shielded • IP66 • For cable ø 6 to 14.5 mm Push-Pull self-latching Keying W code Over 11 shell styles Stainless steel shell Temp. range -55°C to 90°C Shielded UL approved Conform to ARIB standard Conform to SMPTE standard Pre-terminated contacts available Fusion splice • IP68 • For cable ø 8.6 to 16 mm • IP66 • For cable ø 8 to 14 mm Series Contact Configurations Description Media converter (active components) Main Features Push-pull self-latching Over 11 shell styles Temp. range -55°C to 200°C Shielded Intermatable with 1051A004 series Other MEERKAT TM SERBAL TM SHACK TM Ethernet Converter The LEMO MEERKATTM is a triax to fibre media converter. The unit encodes the camera’s triaxial signal and sends it to the OB van using SMPTE 311M cable. The LEMO SERBALTM is a 4 channel multiplexer that makes HD/SDI to fibre conversion possible. The LEMO SHACKTM is a conversion unit from SMPTE cable to single mode optical fibres. The LEMO Ethernet to fibre media converter ensure reliable conversion in harsh environments. LEMO can supply a connecting solution that meets your specific requirements, including special materials, personalized layout and cable assembly • Triaxial 50 or 75 Ω (see our Audio/Video connectors) • Hybrid with: (see the 3K.93C series) 2 fibre optic contacts 2 signal contacts 2 power contacts and ground • BNC connectors (4x) • Hybrid with (see the 3K.93C series) 2 fibre optic contacts 2 signal contacts 2 power contacts and ground • SC, ST, FC or LC fibre optic (single-mode) • Hybrid with (see the 3K.93C series) 2 fibre optic contacts 2 signal contacts 2 power contacts and ground • Single mode fibre • • • • • • • • Converts from coaxial BNC input transmission over standard 3K.93C cable assemblies • Multiple transmission options available: 4 x Tx, 2 x Tx + 2 x Rx, 3 x Tx + 1 x Rx • Audio/Data: passes pre-embedded Audio • Supports all NRZI data formats from 10 Mb/s to 1.5 Gb/s • Signal format: HD/SDI SMPTE 292M, SDI, DVB-ASI, 19.4 Mb/s SMPTE 310, 142-540 Mb/s SMPTE 259M, SDTI • SMPTE elimination unit • For use in pre-fibred venues • Lightweight and portable • Push-Pull self-latching • Temp. range -20°C to 85°C • High shock and vibration resistance • Reliable and secure • Easy to deploy and operate • LED indicators TX signal / RX signal / Power • 10/100 BaseT ethernet • Distance over 20 km • • • • • • • • • • • • • • • • • • • • • Digital encoding and transmission Works in a pair of units Lightweight and portable Immune to EMI CE certified No repeaters needed SD and HD models available • IP68 • For cable ø 2.6 to 10.5 mm Cable assembly Coaxial cable Triaxial cable Video cable Audio cable Multiconductor cable PTFE cable PUR cable Silicone cable Special cable in Viton® Computer cable High voltage cable Special-combinations cable Hybrid cable Spiral cable Fibre optic cable Miniature cable Plastic optical fibre cable Basestation-cable CAT 5 / CAT 7 cable FLAT´N´ROUND-cable Cable assembly Other Underwater (deep sea) V Series W Series U Series Series Contact Configurations Description 03 Series Remote handling self latching connectors suitable for operating in nuclear environments. Screw coupling miniature underwater connectors suitable for pressure up to 60 bars. Screw coupling underwater connectors with stepped inserts for alignment (of multipole version) suitable for pressure up to 30 bars. Screw coupling underwater connectors with alignment key suitable for pressure up to 30 bars. Screw coupling underwater connectors with alignment key for pressure up to 300 bars. • • • • • • Multipole 2 to 4 contacts • Coaxial 50 Ω • • • • • • Multipole 2 to 64 contacts • Multi or mixed contacts with: Coaxial 1 to 14 contacts Fluidic 1 to 14 contacts Fibre optic 1 to 14 contacts • Thermocouple 2 to 6 contacts • Fibre optic • Multipole 2 to 64 contacts • Multi or mixed contacts with: Coaxial 1 to 14 contacts Fibre optic 1 to 14 contacts Main Features N Series • Push-Pull self-latching • 4 sizes • Special shell design for manipulator handling • Temp. range -55°C to 200°C • Stainless steel shell as a standard • Solder, crimp or print contacts • Resistance to 10 6 Gray • EPDM glands • • • • • Screw coupling 2 keying options for multipole Over 20 shell styles Temp. range -55°C to 200°C Shielding: > 100dB at 10Mhz > 80dB at 1 Ghz • Solder or crimp contacts • Rugged housing • • • • • • Screw coupling Multipole with stepped inserts 6 sizes Over 9 shell styles Temp. range -20°C to 200°C Shielding: > 95dB at 10Mhz > 80dB at 1 Ghz • Solder contacts • Rugged housing • • • • • • Screw coupling 4 keying options 6 sizes Over 9 shell styles Temp. range -20°C to 200°C Shielding: > 95dB at 10Mhz > 80dB at 1 Ghz • Solder or crimp contacts • Rugged housing • • • • • • IP66 • For cable ø 7.5 to 28.5 mm • > IP68 • For cable ø 2.4 to 5 mm • > IP68 • For cable ø 1 to 23.5 mm • > IP68 • For cable ø 1 to 23.5 mm • > IP68 • For cable ø 9 to 23 mm Multipole 2 to 64 contacts Coaxial 50 and 75 Ω Triaxial 50 and 75 Ω Thermocouple 2 to 6 contacts Multi or mixed contacts with: Coaxial 1 to 14 contacts High voltage 1 to 21 contacts Fibre optic 1 to 14 contacts Fluidic 1 to 14 contacts Unipole Coaxial 50 or 75 Ω Multipole 2 to 48 contacts Triaxial 50 or 75 Ω Multi or mixed contacts with: Coaxial 1 to 4 contacts Screw coupling 4 sizes Over 3 shell styles Temp. range -20°C to 120°C Shielding: > 95dB at 10Mhz > 80dB at 1 Ghz • Solder, crimp or print contacts COELVER® VAA Series COELVER® SAA Series COELVER® SBA Series COELVER® TAA Series Contact Series Configurations Description Self-latching Push-Pull fibre optic connector with alignment key. Snap-on coaxial connector series MCX (CECC 22220-22221). Screw, Push-Pull or snap-on coaxial connectors DIN 47297-C and CECC 22230. (1.0/2.3) Snap-on connectors according to DIN 41626. Screw, Push-Pull or snap-on connectors according to DIN 47295 and CECC 22240. (1.6/5.6) • Fibre optic single channel • Coaxial 50 Ω • Coaxial 50 and 75 Ω • Coaxial 50 Ω • Coaxial 75 Ω Main Features DIN and CECC standards COELVER® 01 Series • Push-pull self-latching • Fully floating ferrule 1.25mm • For singlemode and multimode fibres • Keying • Temp. range -40°C to 85°C • Over 24 shell styles • Temp. range -55°C to 250°C • Solder, crimp or print contacts • Over 56 shell styles • Temp. range -55°C to 250°C • Solder, crimp or print contacts • Over 11 shell styles • Temp. range -50°C to 155°C • Crimp contacts • Over 28 shell styles • Temp. range -55°C to 250°C • Solder, crimp or print contacts • IP50 • IP50 • IP50 • IP50 • IP50 COELVER® DIN U COELVER® 01 V W 03 N 1D Ethernet SHACKTM SERBALTM MEERKATTM REDEL® F 3K.93C 4A 4M 3T REDEL® D REDEL® K/S 05 5G Y 0A 01 00 R H F M REDEL® P Applications L E S K B Series 2C / 2G Most popular LEMO series by market segment Aviation Automotive Audio / Video HDTV Communications Industrial Control Information Sys. Machine industry Medical Military Nuclear Petroleum Public Sector Research Robotics Test & Measur. Most frequently used in darker colour Checklist to select the best connector solution Coaxial + Multi Triaxial FO + Multi Hybrid + Other specialities Wire gauge, metal or plastic shell, contacts (solder, crimp, print) Keying, environment (harsh, shock,…), vacuumtight Max. test voltage, grounding needs Conductor + dielectric ø, vacuumtight, max. operating voltages models HV + Multi nb of contacts Unipole / Multipole Criterias cable diameter Contact type Cable type (RG?), impedance (50, 75, 120 Ω), max. working frequency Cable type, impedance (50, 75 Ω), max. working frequency Fibre type (singlemode, multimode) Screening efficiency, vacuumtight Screening efficiency, vacuumtight Fibre core & cladding, environment (harsh, shock, …) low + high voltage FO + low + high voltage thermocouple nuclear environment screw thread coupling coaxial + low voltage fluidic + low voltage fluidic & pneumatic non-magnetic shell patch panels triaxial + low voltage thermocouple + low volt. RF coaxial (12 Ghz) hermaphroditic conn. adapters fibre optic + low voltage quadrax remote handling rectangular connectors cable assemblies custom design Coaxial 75 Ω Multi Coaxial Mixed Coax + LV Triaxial 50 Ω Triaxial 75 Ω Mixed Triax + LV Quadrax High Voltage Multi High Voltage Mixed HV + LV Fibre Optic Multi Fibre Optic Mixed FO + LV Thermocouple Fluidic Multi Fluidic Mixed Fluidic + LV Most frequently used in darker colour COELVER® DIN U COELVER® 01 W V 03 N 1D Ethernet SHACKTM SERBALTM MEERKATTM REDEL® 3K.93C 4A 4M 3T F D REDEL® REDEL® K/S 05 5G Y 0A 01 00 P Coaxial 50 Ω R H M F L E K Unipole Multipole REDEL® Contact type S B Series 2C / 2G Contact availability within connector series LEMO HEADQUARTERS SWITZERLAND LEMO SA Chemin des Champs-Courbes 28 - P.O. Box 194 - CH-1024 Ecublens Tel. (+41 21) 695 16 00 - Fax (+41 21) 695 16 02 - e-mail: info@lemo.com SUBSIDIARIES AUSTRIA LEMO Elektronik GesmbH Lemböckgasse 49/E6-3 1230 Wien Tel: (+43 1) 914 23 20 0 Fax:(+43 1) 914 23 20 11 sales@lemo.at JAPAN LEMO Japan Ltd 2-7-22, Mita, Minato-ku, Tokyo, 108-0073 Tel: (+81 3) 54 46 55 10 Fax: (+81 3) 54 46 55 11 lemoinfo@lemo.co.jp CANADA LEMO Canada Inc 111 Esna Park Drive, Unit 1, Markham, Ontario L3R 1H2 Tel: (+1 905) 477 77 22 Fax: (+1 905) 477 78 13 info-canada@lemo.com NETHERLANDS / BELGIUM LEMO Connectors Benelux De Trompet 1060 1967 DD Heemskerk Tel. (+31) 251 25 78 20 Fax (+31) 251 25 78 21 info@lemo.nl CHINA LEMO Electronics (Shanghai) Co., Ltd 5th Floor, Block 6, City of ELITE, 1000 Jinhai Road, Pudong Shanghai, China 201206 Tel: (+86 21) 5899 7721 Fax: (+86 21) 5899 7727 cn.sales@lemo.com NORWAY / ICELAND LEMO Norway A/S Stanseveien 6B 0975 Oslo Tel: (+47) 22 91 70 40 Fax: (+47) 22 91 70 41 info-no@lemo.com DENMARK LEMO Denmark A/S Gammel Mosevej 46 2820 Gentofte Tel: (+45) 45 20 44 00 Fax: (+45) 45 20 44 01 info-dk@lemo.com FRANCE LEMO France Sàrl 24/28 Avenue Graham Bell Bâtiment Balthus 4 Bussy Saint Georges 77607 Marne la Vallée Cedex 3 Tel: (+33 1) 60 94 60 94 Fax: (+33 1) 60 94 60 90 info-fr@lemo.com GERMANY LEMO Elektronik GmbH Hanns-Schwindt-Str. 6 81829 München Tel: (+49 89) 42 77 03 Fax: (+49 89) 420 21 92 info@lemo.de HONG KONG LEMO Hong Kong Ltd Unit 1207, 12/F, Corporation Square, 8 Lam Lok Street, Kowloon Bay, Kowloon - Hong Kong Tel: (+852) 2174 0468 Fax: (+852) 2174 0492 hk.sales@lemo.com HUNGARY REDEL Elektronika Kft Vágóhíd u. 26 1201 Budapest XX. Tel: (+36 1) 421 47 10 Fax: (+36 1) 421 47 57 info-hu@lemo.com ITALY LEMO Italia srl Viale Lunigiana 25 20125 Milano Tel: (+39 02) 66 71 10 46 Fax: (+39 02) 66 71 10 66 sales.it@lemo.com LEMO SINGAPORE LEMO Asia Pte Ltd 4 Leng Kee Road, #06-09 SiS Building Singapore 159088 Tel: (+65) 6476 0672 Fax: (+65) 6474 0672 sg.sales@lemo.com SPAIN / PORTUGAL IBERLEMO SAU Brasil, 45, 08402 Granollers Barcelona Tel: (+34 93) 860 44 20 Fax: (+34 93) 879 10 77 info-es@lemo.com Madrid Office Antonio López, 96, 28019 Madrid Tel: (+34 91) 469 99 19 Fax: (+34 91) 469 99 59 SWEDEN / FINLAND LEMO Nordic AB Mariehällsvägen 39A 168 65 Bromma Tel: (+46 8) 635 60 60 Fax: (+46 8) 635 60 61 info-se@lemo.com SWITZERLAND LEMO Verkauf AG Grundstrasse 22 B 6343 Rotkreuz Tel: (+41 41) 790 49 40 Fax: (+41 41) 790 49 43 ch.sales@lemo.com UNITED KINGDOM LEMO UK Ltd 12-20 North Street Worthing, West Sussex, BN11 1DU Tel: (+44 1903) 23 45 43 Fax: (+44 1903) 20 62 31 lemouk@lemo.com USA LEMO USA Inc P.O. Box 2408 Rohnert Park, CA 94927-2408 Tel: (+1 707) 578 88 11 (+1 800) 444 53 66 Fax:(+1 707) 578 08 69 info@lemousa.com DISTRIBUTORS AUSTRALIA, BRAZIL, CZECH REPUBLIC, GREECE, INDIA, ISRAEL, NEW ZEALAND, PAKISTAN, POLAND, RUSSIA, SOUTH AFRICA, SOUTH KOREA, TAIWAN, TURKEY, UKRAINE www.lemo.com © CAT.SG.LEN.P0909, pdf updated December 2012 LEMO Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: LEMO: FFS.00.161.MN FGG.00.303.CLAD35Z PSA.00.250.CTLC29 FGG.00.304.CLAD35Z ERN.00.250.NTL ASF.00.250.NTA FRT.00.250.CTA50 FFV.00.250.NTAE31 RMA.00.250.NTM HGG.00.304.CLLPV FPL.00.250.NTD EGG.00.302.CYM EHG.00.302.CLL EHP.00.250.CTL EPE.00.250.NTN EPE.00.250.NTNZ EPL.00.650.NLNY EPS.00.250.NTN ERN.00.650.CLL EWF.00.250.CTLPV EWF.00.250.NTLPV EZG.00.302.NLN GMD.00.025.DA GRA.00.269.GJ GRA.00.269.GR GRA.00.269.GV HGP.00.250.NTLPV FLA.00.250.CTAC29 FLA.00.250.CTAC31Z GBA.00.250.FN RAD.00.113.CTM RAD.00.250.NTM VPS.00.250.CTLE31 XRB.00.303.NLN XAN.M13.GLA.6G XAN.M22.GLA.6G XKN.M13.GLLG XKN.M22.GLLG XRN.M13.GLL.6G XRN.M22.GLL.6G XAN.M08.GLA.6A XAN.M22.GLA.6A XKN.M08.GLLA XRN.M08.GLL.6A XRN.M13.GLL.6A XRN.M22.GLL.6A XAN.M22.GLA.6R XKN.M13.BLLB XKN.M22.GLMG XAN.M13.BLA.6BZ ERA.00.250.NTL ERA.00.250.CTL ERN.00.250.CTL FFS.00.250.NTCE52 PCA.00.250.CTLC29 FFS.00.250.NTCE31 FGG.00.302.CLAD27 FGG.00.304.CLAD35 EGG.00.302.CLL EGG.00.304.CLL RAD.00.250.CTM PHG.00.304.CLLZ PFG.00.304.CLLD35 ABC.00.250.NTM APF.00.250.DTAR ASA.00.250.NTL ASB.00.250.NTM ASG.00.250.NTC EEG.00.302.CLL EEG.00.303.CLL FFF.00.250.CTAC22 FFS.00.250.CTAE24 FFS.00.250.CTAE45 FFY.00.113.CTAC52Z FGG.00.303.ZLA PFB.00.303.CLLD27 PHG.00.304.CLLD35 FFC.00.250.CTAC22Z GSC.00.290.CD35 XAN.M08.GLA.3G XAN.M10.GLA.3G XAN.M13.GLA.3G XAN.M08.GLA.3GZ XAN.M22.GLA.5G XAN.M06.GLA.6G XAN.M08.GLA.6G XAN.M08.GLA.6GZ XAN.M13.GLA.6GZ XAN.M22.GLA.6GZ XRN.M22.GLL.5G XRN.M08.GLL.6G XRN.M08.GLL.6GZ XRN.M13.GLL.6GZ XRN.M22.GLL.6GZ XLN.M08.GLLG XLN.M10.GLLG XLN.M13.GLLG XLN.M22.GLLG XKN.M06.GLLG XKN.M08.GLLG
FGG.00.735.DN 价格&库存
很抱歉,暂时无法提供与“FGG.00.735.DN”相匹配的价格&库存,您可以联系我们找货
