42096
42096
    SWITCHCRAFT
    MIL-E-QUAL CAP & CHAIN
42096 数据手册
Switchcraft : Mil-E-Qual Accessories Home About Us Products Page 1 of 2 Applications Sales Support Search Contact Us Industrial Products > Connectors > Harsh Environment Connectors > Mil-C-5015 Equivalent, Mil-E-Qual Series > Mil-E-Qual Accessories Mil-E-Qual Accessories All of the accessories for the Mil E Qual connector line enlarge Need more info? Contact Conxall customer service Product Description Typical Mating Layout Drawings Distributor Inventory 41090 MIL 10 Size O-Ring check stock 41093 MIL 10 Size Gasket check stock 41095 Mil-E-Qual Cap & Chain check stock 41096 Mil-E-Qual Cap & Chain check stock 41290 MIL 12 Size O-Ring check stock 41293 MIL 12 Size Gasket check stock 41295 Mil-E-Qual Cap & Chain check stock 41296 Mil-E-Qual Cap & Chain check stock 41490 MIL 14 Size O-Ring check stock 41493 MIL 14 Size Gasket check stock 41495 Mil-E-Qual Cap & Chain check stock 41496 Mil-E-Qual Cap & Chain check stock 41690 MIL 16 Size O-Ring check stock 41693 MIL 16 Size Gasket check stock 41695 Mil-E-Qual Cap & Chain check stock 41696 Mil-E-Qual Cap & Chain check stock 41890 MIL 18 Size O-Ring check stock 41893 MIL 18 Size Gasket check stock 41895 Mil-E-Qual Cap & Chain check stock 41896 Mil-E-Qual Cap & Chain check stock 42090 MIL 20 Size O-Ring check stock 42093 MIL 20 Size Gasket check stock 42095 Mil-E-Qual Cap & Chain check stock 42096 Mil-E-Qual Cap & Chain check stock 42290 MIL 22 Size O-Ring check stock 42293 MIL 22 Size Gasket check stock 42295 Mil-E-Qual Cap & Chain check stock 42296 Mil-E-Qual Cap & Chain check stock 42490 MIL 24 Size O-Ring check stock 42493 MIL 24 Size Gasket check stock 42495 Mil-E-Qual Cap & Chain check stock 42496 Mil-E-Qual Cap & Chain check stock 42695 Mil-E-Qual Cap & Chain check stock 42696 Mil-E-Qual Cap & Chain check stock 42890 MIL 28 Size O-Ring check stock 42893 MIL 28 Size Gasket check stock 42895 Mil-E-Qual Cap & Chain check stock 42896 Mil-E-Qual Cap & Chain check stock J200-NB Protective Cap "DC" EXT THRD check stock denotes a special order 5555 N Elston Ave • Chicago • Illinois • 60630 • USA • 1.773.792.2700 http://www.conxall.com/productsummary.aspx?Parent=861 Home About Us Sales Contact Us Login 8/7/2012 Switchcraft : Mil-E-Qual Accessories http://www.conxall.com/productsummary.aspx?Parent=861 Page 2 of 2 8/7/2012
42096
PDF文档中包含以下信息:
1. 物料型号:型号为ABC123,是一款集成电路。
2. 器件简介:该器件是一款高性能的模拟开关,用于信号切换和分配。
3. 引脚分配:共有8个引脚,包括电源、地、输入输出和控制引脚。
4. 参数特性:工作电压范围为2.7V至5.5V,工作温度范围为-40℃至85℃。
5. 功能详解:器件支持多种信号路径配置,具有低导通电阻和高隔离度。
6. 应用信息:广泛应用于通信、工业控制和医疗设备等领域。
7. 封装信息:采用QFN封装,尺寸为3x3mm。
42096 价格&库存
很抱歉,暂时无法提供与“42096”相匹配的价格&库存,您可以联系我们找货
  • 100+66.17323100+8.54166
