FFM.1B.131.LC
FFM.1B.131.LC
    LEMO(雷莫)
    FFM.1B.131.LC
FFM.1B.131.LC 数据手册
MULTIPOLE CONNECTORS XB SERIES Patent P Technoending logy XB is a new size to complete the B Series connector range LEMO B Series connectors are now available with a new connector size. The XB Series can accommodate 12 or 22 electrical contacts. This connector is an intermediate connector size between the well known 1B and 2B Series. The market need for a compact connector resulted in this new high contact density product. Features endurance: over 5000 mating cycles temperature range: -55°C to + 250°C protection index: IP 50 (when mated) 360° screening for full EMC shielding high packing density for space savings Models FGG Straight plug, key (G) or keys (A and E), cable collet 44 33.5 ø 13 Part Number S 10 Number of contacts FGG.XB.312.CLAD•• FGG.XB.322.CLAD•• 12 22 S 11 Note: Replace by •• collet size reference (see table). FGG Straight plug, key (G) or keys (A and E), cable collet and nut for fitting a bend relief 47.5 37 ø 13 Part Number S 10 Number of contacts FGG.XB.312.CLAD••Z FGG.XB.322.CLAD••Z 12 22 S 11 Note: Replace by •• collet size reference (see table). The bend relief must be ordered separately. EGG Fixed socket, key (G) or keys (A and E), nut fixing 23.5 20 1.5 S 17 ø 16 ø 19 M 14 x 1 Part Number 7 maxi Number of contacts EGG.XB.312.CLL EGG.XB.322.CLL 12 22 S 12.5 ECG Fixed socket with two nuts, key (G) or keys (A and E) (back panel mounting) 23.5 20 3.5 S 17 ø 18 ø 19 M 14 x 1 Part Number 6 maxi ECG.XB.312.CLL ECG.XB.322.CLL ECG Fixed socket with two nuts, key (G) or keys (A and E) and straight contact for printed circuit (back panel mounting) 20 ø 18 M 14 x 1 ø 19 3.5 Part Number 6 maxi 12 22 S 12.5 23 S 17 Number of contacts Number of contacts ECG.XB.312.CLN ECG.XB.322.CLN 12 22 S 12.5 PHG Free socket, key (G) or keys (A and E), cable collet 46 ø 13 Part Number S 10 S 11 Number of contacts PHG.XB.312.CLLD•• PHG.XB.322.CLLD•• 12 22 Note: Replace by •• collet size reference (see table). Note: All dimensions are in millimetres. PHG Free socket, key (G) or keys (A and E), cable collet and nut for fitting a bend relief 49.5 ø 13 S 10 Number of contacts Part Number PHG.XB.312.CLLD••Z PHG.XB.322.CLLD••Z S 11 12 22 Note: Replace by •• collet size reference (see table). The bend relief must be ordered separately. Insert configuration and electrical characteristics Female solder contacts Contact type Solder contact 2 Rated current (A) 3 Test voltage (kV rms) Contact-shell 3 Test voltage (kV rms) Contact-contact 2 Print (straight) 1 Solder 4 ø A (mm) 4 Number of contacts 1 Reference øA Male solder contacts 312 12 0.7 ● ● 1.35 1.65 5.00 322 22 0.5 ● ● 0.50 0.90 1.50 øB øA D type collets for XB series Collet ø Reference Cable ø Type •• øA øB max. min. D D D D 52 62 72 82 5.2 6.2 7.2 8.2 7.2 7.2 7.2 7.2 5.0 6.0 7.0 8.0 4.4 5.4 6.4 7.4 Nut for fitting a bend relief Bend relief GMA.1B.045.DG GMA.1B.054.DG GMA.1B.065.DG – FFM.1B.131.LC – Contacts (solder type) øA Conductor øC Contact Solid Stranded Reference øA øC 312 322 øA (mm) øC (mm) AWG max. 0.7 0.5 0.80 0.45 22 28 (mm2) Section max. 0.34 0.09 AWG max. Section (mm2) max. 221) 28 0.34 0.09 Note: 1) for a given AWG, the diameter of some stranded conductor designs is larger than the solder cup diameter. Make sure that the maximum conductor diameter is smaller than ø C. Alignment Key and Polarized Keying System XB series connector model part numbers are composed of three letters. The LAST LETTER indicates the key position. α Contact type Reference Nb of Angles Series keys XB β G A E ● First choice alternative ● Special order alternative 1 2 2 α β 0° 30° 120° Note Plug Socket male male male female female female ● ● ● Accessories GMA Bend relief for FGG and PHG models with nut for fitting a bend relief Dimensions (mm) Bend relief Cable ø A L max. min. Part Number GMA.1B.040.DG GMA.1B.045.DG GMA.1B.054.DG GMA.1B.065.DG øA L 4.0 4.5 5.4 6.5 30 30 30 30 4.4 4.9 6.0 7.0 4.0 4.5 5.4 6.5 Ref. Colour Ref. Colour Ref. Colour A B G blue white grey J M N yellow brown black R S V red orange green Note: Material: Polyurethane elastomer Temperature range in dry atmosphere: -40°C +80°C Note: The last letter «G» of the part number indicates the colour grey of the bend relief. For others colour, refer to the above table and replace letter «G» by the letter of the colour required. Panel cut-out PCB drilling pattern EGG-ECG 312 322 21.5 mini + 0.1 0 45° 25’ 51° Cable stripping lengths Type 312 322 S ø 5.7 Mounting nut torque Cable stripping lengths (mm) ø contact (mm) Connector T ø 0.6 ø 3.1 ø 0.8 25 °4 2 ø 5.4 + 0.1 0 ø 2.4 12.6 L 12°51’ ’ ø 14.1 22°30’ L S T 0.7 0.5 16.5 17.5 7.5 8.0 3.5 4.0 Torque (Nm) Solder 5.0 Note: all dimensions are in millimetres. Refer to B series catalog for general characteristics LEMO HEADQUARTERS SWITZERLAND LEMO SA Chemin des Champs-Courbes 28 - P.O. Box 194 - CH-1024 Ecublens Tel. (+41 21) 695 16 00 - Fax (+41 21) 695 16 02 - e-mail: info@lemo.com www.lemo.com CAT.XB.LEN.P0307 CHF 1.50 / EURO 1 / USD 1.1 / RMB 10 Data subject to change, printed in Switzerland, March 2007 Updated May 2008 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: LEMO: FFM.1B.131.LC
FFM.1B.131.LC 价格&库存
很抱歉,暂时无法提供与“FFM.1B.131.LC”相匹配的价格&库存,您可以联系我们找货
FFM.1B.131.LC
    • 1+15.600441+2.00003
    库存:678
