FLEXIBLE SEALED
CIRCULAR SYSTEMS
FEATURES & BENEFITS
• Metal or plastic, 12 mm, 16 mm and 22 mm shells
• Choice of pin configuration and gender
• Bayonet-style latching systems meet IP68 requirements
• Cost-effective crimp version available (samtec.com/crimp)
• Variety of end 2 options for panel-to-board applications
• Mini push-pull latching system meets IP67 requirements for
dust and waterproof sealing
ACX-12
ACX-16
ACX-22
MAX
MAX
MAX
5.0
11.6
8.3
No. of Pins
2, 4, 5
No. of Pins
2, 10, 14
No. of Pins
8, 20, 30
A
Kitted components
for efficient field
assembly
Dust caps
available
m
p
s
A
m
p
s
A
m
p
s
KEY SPECIFICATIONS
INSULATOR MATERIAL
TERMINAL MATERIAL
CONTACT MATERIAL
OPERATING TEMP
RANGE
Thermoplastic
Brass
Brass/BeCu
-10 ºC to +105 ºC (ACX-16)
-10 ºC to +80 ºC (ACX-12)
-10 ºC to +105 ºC (ACX-22)
F-221
HOUSING
Thermoplastic (-P)
Zinc Alloy (-M)
samtec.com/AccliMate
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
12 mm • IP68 SEALED CABLE ASSEMBLY
SERIES
- 12
ACP
LEAD STYLE
–01
Terminal
= 1.0 mm DIA (4)
terminals or sockets
(24 AWG)
ACR
–02
Socket
PLATING
OPTION
–G
LENGTH
–“XX.XX”
= 10 µ" (0.25 µm)
Gold over 50 µ"
(1.27 µm)
Ni on contact
= Length in
meters
(00.25 m min.
to 50.00 m max.)
Standard
lengths
= 1.0 mm DIA (5)
(24 AWG)
END 1
END 2
–T
HOUSING
MATERIAL
–T
= Terminal
–S
= Socket
(N/A with
End 2 -T)
–P
= Terminal
(ACP only)
= Plastic
–S
= Metal
–1
= Orange,
45°
–M
= Socket
(ACP only)
KEYING
OPTIONS
–BC
= Blunt Cut
–05
–S1
= 1.0 mm DIA (2)
(24 AWG) + 0.5 mm
DIA (4) terminals
or sockets (28 AWG)
= Connector
determine by
lead style. See
chart for end 2
connector used.
(ACR only)
ACP-12
End 1/2 Mates:
ACR-12
ACRK-12
(1.0) .040
DIA (2)
(1.0) .040
DIA (5)
(1.0) .040
DIA (4)
(0.5) .020
DIA (4)
Overall Length (XX.XX) ± 2%
(9.30)
.366
(18.50)
.728
–P HOUSING
–M HOUSING
View complete specifications at: samtec.com?ACP-12
PANEL OPENING
(1.0) .040
DIA (2)
ACR-12
(1.0) .040
DIA (4)
End 1 Mates:
ACP-12
ACPK-12
(16.10)
.634
DIA
(1.0) .040
DIA (5)
(0.5) .020
DIA (4)
End 2 Mates:
IPL1
(13.60) .535
Overall Length (XX.XX) ±2%
(22.00)
.866
END 1
–01 END 2 (MMSS)
LEAD
STYLE
–S1 END 2
–01
MMSS (24 AWG)
–02
MMSS (24 AWG)
–05
MMSS (24 AWG (2x),
28 AWG (4x))
MATES
WITH –S1
IPL1
View complete specifications at: samtec.com?ACR-12
KITS AVAILABLE
CURRENT RATING
LEAD STYLE
PINS POWERED
CCC per PIN
–01
4
3.8 A
–02
5
3.6 A
–05
2
(plus 4 signal pins powered @ 1.2 A)
5.0 A
www.samtec.com?ACPK-12
www.samtec.com?ACRK-12
For general reference only. Contact AccliMate@samtec.com for applications requiring higher current carrying capacity.
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
F-221
很抱歉,暂时无法提供与“DCA-ACR-12-M-3”相匹配的价格&库存,您可以联系我们找货
