FLEXIBLE SEALED
CIRCULAR SYSTEMS
FEATURES & BENEFITS
• Metal or plastic, 12 mm, 16 mm and 22 mm shells
• Choice of pin configuration and gender
• Bayonet-style latching systems meet IP68 requirements
• Cost-effective crimp version available (samtec.com/crimp)
• Variety of end 2 options for panel-to-board applications
• Mini push-pull latching system meets IP67 requirements for
dust and waterproof sealing
ACX-12
ACX-16
ACX-22
MAX
MAX
MAX
5.0
11.6
8.3
No. of Pins
2, 4, 5
No. of Pins
2, 10, 14
No. of Pins
8, 20, 30
A
Kitted components
for efficient field
assembly
Dust caps
available
m
p
s
A
m
p
s
A
m
p
s
KEY SPECIFICATIONS
INSULATOR MATERIAL
TERMINAL MATERIAL
CONTACT MATERIAL
OPERATING TEMP
RANGE
Thermoplastic
Brass
Brass/BeCu
-10 ºC to +105 ºC (ACX-16)
-10 ºC to +80 ºC (ACX-12)
-10 ºC to +105 ºC (ACX-22)
F-221
HOUSING
Thermoplastic (-P)
Zinc Alloy (-M)
samtec.com/AccliMate
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
22 mm • IP68 SEALED CABLE ASSEMBLY
SERIES
- 22
ACP
LEAD STYLE
–01
Terminal
= 1.0 mm DIA (30)
terminals or sockets
(24 AWG)
ACR
–02
Socket
PLATING
OPTION
–G
LENGTH
–“XX.XX”
= 10 µ"
(0.25 µm) Gold
over 50 µ” (1.27
µm) Ni on contact
HOUSING
MATERIAL
–T
= Terminal
–S
= Socket
Standard
lengths
END 2
–T
= Length in
meters
(00.25 m min.
to 50.00 m max.)
= 1.0 mm DIA (20)
(24 AWG)
END 1
KEYING
OPTIONS
–P
= Terminal
(ACP only)
= Plastic
–S
= Metal
–M
= Socket
(ACP only)
–1
= Orange,
45°
–BC
= Blunt Cut
–03
–S1
= 1.5 mm DIA (8)
(16 AWG)
= Connector
determine by lead
style. See chart for
end 2 connector
used. (ACR only)
(1.0) .040
DIA (30)
(1.0) .040
DIA (20)
(1.5) .060
DIA (8)
ACP-22
End 1/2 Mates:
ACR-22
ACRK-22
–01
–02
–03
Overall Length (XX.XX) ± 2%
(32.50)
1.280
(19.50)
.768
–P HOUSING
–M HOUSING
View complete specifications at: samtec.com?ACP-22
(1.0) .040
DIA (30)
ACR-22
PANEL OPENING
(1.5) .060
DIA (8)
(1.0) .040
DIA (20)
(12.25)
.482
End 1 Mates:
ACP-22
ACPK-22
(27.50)
1.08
DIA
End 2 Mates:
IPL1, MPT
–01
–02
–03
Overall Length = (XX.XX) ± 2%
LEAD
STYLE
–01
–02
(33.00)
1.299
–03
–01 END
–S1 END 2
MATES
WITH –S1
MMSD (24 AWG)
IPL1
MPSS (16 AWG
MPT
–01 END 2 (MMSD)
View complete specifications at: samtec.com?ACR-22
KITS AVAILABLE
CURRENT RATING
LEAD STYLE
PINS POWERED
CCC per PIN
–01
30
2.0 A
–02
2.3 A
–03
8
8.3 A
For general reference only. Contact AccliMate@samtec.com for applications requiring higher current carrying capacity.
www.samtec.com?ACPK-22
www.samtec.com?ACRK-22
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
F-221
很抱歉,暂时无法提供与“DCA-ACR-22-P-1”相匹配的价格&库存,您可以联系我们找货
