GMA.2B.071.RV
GMA.2B.071.RV
    LEMO(雷莫)
    BENDRELIEF
GMA.2B.071.RV 数据手册
GMA.2B.071.RV www.lemo.com SUMMARY # Wires Image is for illustrative purpose only Series 2B Termination type No contacts / Accessory IP rating 0 AWG wire size 0.00 - 0.00 Cable Ø 7.10 - 7.90 mm Status active Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model GMA*: Bend relief Green Keying 2 keys (alpha=30, plug: male contacts, receptacle: female contacts) Housing Material PPSU (Polyphenylsulfone, creme)shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Variant V : Green Weight 1.91 g Performance Configuration Insulator Rated Current Others Temp (min / max): -60°C / +200°C Temperature range in water steam: +140°C LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/2 DRAWINGS Dimensions A L mm. 7.1 41 in. 0,28 1,61 RECOMMENDED BY LEMO Tools LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/2
GMA.2B.071.RV 价格&库存
很抱歉,暂时无法提供与“GMA.2B.071.RV”相匹配的价格&库存,您可以联系我们找货
