Additional Resources:
Product Page
3D Model
PCB Footprint
date
11/05/2019
page
1 of 3
MODEL: PJ-044BH │ DESCRIPTION: DC POWER JACK
FEATURES
2.5 mm center pin
5.0 A rating
vertical orientation
through hole
RoHS
SPECIFICATIONS
parameter
conditions/description
min
rated input voltage
typ
rated input current
contact resistance1
between terminal and mating plug
between terminal in a closed circuit
insulation resistance
at 500 Vdc
voltage withstand
at 50/60Hz for 1 minute
any direction for 10 seconds
-25
life
A
50
30
mΩ
mΩ
500
Vac
3
kg
500
g
85
°C
5,000
flammability rating
UL94V-0
RoHS
yes
Note:
5.0
MΩ
0.3
operating temperature
units
Vdc
100
insertion/withdrawal force
terminal strength
max
24
cycles
1. When measured at a current of less than 100 mA/1 kHz
SOLDERABILITY
parameter
min
typ
max
units
wave soldering
dipped in solder pot for 5 ±0.5 seconds
255
260
265
°C
cuidevices.com
Product Page
3D Model
PCB Footprint
CUI Devices │ MODEL: PJ-044BH │ DESCRIPTION: DC POWER JACK
date 11/05/2019│ page 2 of 3
MECHANICAL DRAWING
units: mm[inches]
tolerance:
X.X ±0.2mm
X.XX ±0.1mm
X.XXX ±0.05mm
MATERIAL
PLATING
center pin
copper
nickel
terminal 1
brass
silver
terminal 2
copper alloy
silver
terminal 3
brass
silver
plastic
PBT
9.0 0.354
3.00 0.118
6.50 0.256
2.50 0.098
11.0 0.433
2.00 0.079
6.50 0.256
2.50 0.098
12.0 0.472
3.50 0.138
1.00X3.50
1
1
5.2 0.205
1.00X3.00
1.70 0.067
1.00X2.50
3
2
1.0 0.039
3
2
4.0 0.157
3.0 0.118
0.3 (TYP)
1.0 0.39
3.5 0.138
14.2 0.559
PCB LAYOUT
TOP VIEW
1
3
2
SCHEMATIC
MATING PLUG
Jack Insertion Depth: 9.0 mm
Note:
Model
PJ-044BH
Center Pin
Ø2.5 mm
1. All specifications measured at 10~35°C, humidity at 45~85%, under standard atmospheric pressure, unless otherwise noted.
cuidevices.com
Product Page
3D Model
PCB Footprint
date 11/05/2019│ page 3 of 3
REVISION HISTORY
rev.
description
date
1.0
initial release
07/30/2007
1.01
applied new spec template
09/30/2013
1.02
increased voltage rating
04/28/2016
brand update
11/05/2019
1.03
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no
responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any
component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or
effectiveness.
cuidevices.com
很抱歉,暂时无法提供与“PJ-044BH”相匹配的价格&库存,您可以联系我们找货
