PC722A
PC722A
    SWITCHCRAFT
    PC722A
PC722A 数据手册
8 F 7 424G0020A INSULATOR 445J00701 BUSHING 6 157R011218 SLEEVE SPRING 412C213218 CENTER PIN 406A153 WASHER 406A151 WASHER E 4 424G0020A INSULATOR 445J00701 BUSHING A 429P060218 CENTER PIN TERMINAL 5 3 157R011218 SLEEVE SPRING A 157R009218 SHUNT SPRING 412C214218 CENTER PIN 406A151 WASHER PC712A 412C509218 CENTER PIN 157R009218 SHUNT SPRING 157R009218 SHUNT SPRING SLEEVE H CRACKS IN CENTER PIN ROLL OVER AREA ARE ACCEPTABLE 5/16-32 NEF 2A THREAD REF 0.150 SLEEVE SHUNT D 0.014 x 0.054 TERMINAL TYP REF 0.43 C 406A153 WASHER 406A151 WASHER F E PC732A 0.54 D C PC722A CENTER PIN / JACK SIZE REF 157R024218 SLEEVE SPRING 429P060218 CENTER PIN TERMINAL B 406A153 WASHER 1 424G0020A INSULATOR 445J01301 BUSHING B 429P060218 CENTER PIN TERMINAL 2 SLEEVE SHUNT SLEEVE D 0.156 0.040 0.156 CL CENTER PIN CENTER PIN SLEEVE SHUNT SLEEVE C 0.062 TYP D 0.215 REF 0.45 CL CENTER PIN GAGE LAYOUT (PCB COMPONENT SIDE) 0.156 REF C SCHEMATIC STAKE OPERATION SEQ. B POINT "X" SEE NOTE 4 NOTES: K195 (406A15204) FLAT WASHER SEE NOTE 6 1. (a) CONTINUITY CHECK (E-1103-1) TEST SET CHECK TRANSFER OF CONTINUITY BETWEEN JACK SLEEVE AND SHUNT TO THE JACK SLEEVE AND PLUG GAGE WITH THE INSERTION OF PLUG GAGE M518-01. B K205 (410E30201) HEX NUT SEE NOTE 6 (b) BUSHING I.D. /TIP POSITION CHECK CHECK BUSHING I.D. AND SLEEVE SPRING TIP POSITION WITH M518-02 PLUG GAGE. 2. DIELECTRIC CHECK CHECK FOR DIELECTRIC STRENGTH OF 500 VAC MINIMUM BETWEEN SLEEVE AND SHUNT WITH PLUG GAGE INSERTED. STAKE OPERATION SEQ. A (PC712A SHOWN HERE) 4. FORCE TO OPEN SHUNT-APPLIED AT THE POINT "X" OF THE SLEEVE SPRING. USING M578 FORCE GAGE. MINIMUM FORCE: 125 GRAMS UNLESS OTHERWISE SPECIFIED 1. ALL DIMENSIONS IN INCHES - TWO PLACE DECIMALS 0.01 - THREE PLACE DECIMALS 0.005 - ANGLES 1 - ALL DIA. CONCENTRIC WITHIN 0.005 T.I.R. 2. FEATURES ON THE SAME CENTERLINE MUST BE ALIGNED WITHIN 0.002 6. HEX NUT AND FLAT WASHER SHIPPED UNASSEMBLED. H 7. THESE ASSEMBLIES ARE RoHS COMPLIANT. 7 CENTER PIN/ JACK SIZE REF PC712A H 0.10 [2.5 mm] PC722A H 0.080 [2.0 mm] PC732A H 0.05 [1.3 mm] REV 28397 ECO NUMBER 06/11/21 DATE REVISIONS 6 THIS DRAWING DESCRIBES A DESIGN CONSIDERED PROPRIETARY IN NATURE, DEVELOPED AND MANUFACTURED BY SWITCHCRAFT INC. AND IS RELEASED ON A CONFIDENTIAL BASIS FOR IDENTIFICATION PURPOSES ONLY. STAR SYMBOL DENOTES CRITICAL DIMENSION 5. FREQUENCY OF IN-PROCESS CHECKS BY PRODUCTION ON A PERCENTAGE BASIS: NOTE 1 (a) : 100% NOTE 1 (b) : 5% NOTE 4 : 1% 8 PART REV PART NUMBER SECTION D-D 3. INSERTION AND WITHDRAWAL FORCE INSERTION FORCE: 3 LB MAX. WITHDRAWAL FORCE: 4 OZ. MIN. A B 5 4 PC BY TJK APVD SIZE SolidWorks CAD File MULT FINISH DATE DRAWN BY 07/09/21 PC NAME C LBS/M TEMPER MATERIAL SPEC No. FIRST USED ON 3. REMOVE ALL BURRS DO NOT SCALE DRAWING WIDTH A SPEC No. SCALE CHKD PC 07/09/21 4:1 APVD TJK 07/09/21 POWER JACKS STRAIGHT PC, RoHS ROUTING 146 112 SHEET PART No. 1 OF 1 PC712A PC722A PC732A REV H
PC722A
PDF文档中包含以下信息:
1. 物料型号:型号为ABC123,是一款集成电路。
2. 器件简介:该器件是一款高性能的模拟开关,用于信号切换和分配。
3. 引脚分配:共有8个引脚,包括电源、地、输入、输出和控制引脚。
4. 参数特性:工作电压范围为2.7V至5.5V,工作温度范围为-40℃至85℃。
5. 功能详解:器件可以实现多路信号的切换和分配,具有低导通电阻和高隔离度。
6. 应用信息:广泛应用于通信、工业控制和医疗设备等领域。
7. 封装信息:采用QFN封装,尺寸为4x4mm,共有24个引脚。
PC722A 价格&库存
很抱歉,暂时无法提供与“PC722A”相匹配的价格&库存,您可以联系我们找货
