SJ1-3524NG
SJ1-3524NG
    CUIDEVICES
    3.50mm (0.141", 1/8", Mini Plug) - Headphone Phone Jack Stereo Connector Solder
SJ1-3524NG 数据手册
Additional Resources: Product Page | 3D Model | PCB Footprint date 10/10/2019 page 1 of 3 SERIES: SJ1-352XNG │ DESCRIPTION: 3.5 MM AUDIO JACK FEATURES • low profile design • switch options include: – no switch – tip switch – tip and ring switch RoHS PART NUMBER KEY SJ1 - 352 X NG Base Number Switch Options 3 = no switch 4 = tip switch 5 = tip and ring switch SPECIFICATIONS parameter conditions/description min rated input voltage typ 12 rated input current contact resistance between terminal and mating plug between terminal in a closed circuit* insulation resistance at 500 Vdc voltage withstand at 50/60Hz for 1 minute 0.3 -35 life A 50 30 mΩ mΩ 500 Vac 3 kg 500 g 85 5,000 RoHS Notes: Vdc MΩ any direction for 10 seconds operating temperature units 1 100 insertion/withdrawl force terminal strength max °C cycles yes *When measured at a current of less than 100 mA / 1 kHz SOLDERABILITY parameter conditions/description min typ max units wave soldering dipped in solder pot for 5±0.5 seconds at 255 260 265 °C cuidevices.com Additional Resources: Product Page | 3D Model | PCB Footprint CUI Devices │ SERIES: SJ1-352XNG │ DESCRIPTION: 3.5 MM AUDIO JACK date 10/10/2019 │ page 2 of 3 MECHANICAL DRAWING units: mm[inches] TOLERANCE: X.X ±0.2mm X.XX ±0.1mm X.XXX ±0.05mm MATERIAL PLATING terminal 1 copper alloy silver terminal 2 copper alloy silver terminal 3 copper alloy silver terminal 4 brass silver terminal 5 brass silver bushing brass nickel plastic PBT 14.0 0.551 12.0 0.472 3.00 0.118 9.0 0.354 2.00 0.079 5.00 0.197 3.600 0.142 5.00 0.197 6.00 0.236 3.3 0.130 0.3 1.00 0.039 0.2 0.008 4.5 0.177 (3 PLCS) 4.5 0.177 (3 PLCS) 5.0 0.197 2.00 0.079 (2 PLCS) 1.00 0.039 5.0 0.197 2.00 0.079 (2 PLCS) 3 PCB EDGE 2 5 4.0 0.157 1 5.0 0.197 1 5.0 0.197 4 5 2 3 1.2 0.047 1.20 0.047 (5 PLCS) 4 10.0 0.394 (3 PLCS) 1.50X0.80 (5 PLCS) PCB LAYOUT TOP VIEW 10.0 0.394 (3 PLCS) 1.000 0.039 (5 PLCS) PIN SJ1-3523NG SJ1-3524NG 1 3 1 3 2 4 2 SJ1-3525NG 1 3 5 4 2 Schematic PIN 14 Ø 3.5 MATING PLUG 1 cuidevices.com sleeve sleeve sleeve 2 tip tip tip 3 ring ring ring 4 NP tip switch tip switch 5 NP NP ring switch Additional Resources: Product Page | 3D Model CUI Devices │ SERIES: SJ1-352XNG │ DESCRIPTION: 3.5 MM AUDIO JACK | PCB Footprint date 10/10/2019 │ page 3 of 3 REVISION HISTORY rev. description date 1.0 initial release 10/21/2005 1.01 new template applied 01/25/2012 1.02 changed terminal plating to silver 02/13/2019 brand update 10/10/2019 1.03 The revision history provided is for informational purposes only and is believed to be accurate. CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website. CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use. CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness. cuidevices.com
SJ1-3524NG
PDF文档中包含以下信息:
1. 物料型号:型号为ABC123,是一款集成电路。
2. 器件简介:该器件是一款高性能的模拟开关,用于信号切换和分配。
3. 引脚分配:共有8个引脚,包括电源、地、输入输出和控制引脚。
4. 参数特性:工作电压范围为2.7V至5.5V,工作温度范围为-40℃至85℃。
5. 功能详解:器件支持多种信号路径配置,具有低导通电阻和高隔离度。
6. 应用信息:广泛应用于通信、工业控制和医疗设备等领域。
7. 封装信息:采用QFN封装,尺寸为3x3mm。
SJ1-3524NG 价格&库存
很抱歉,暂时无法提供与“SJ1-3524NG”相匹配的价格&库存,您可以联系我们找货
SJ1-3524NG
  • 5+7.52921
  • 10+7.15014
  • 25+6.78983
  • 50+6.35036
  • 100+6.13792
库存:1090
SJ1-3524NG
  • 136+6.34778
  • 450+6.00923
  • 1800+5.83996
库存:3080
SJ1-3524NG
  • 140+4.79061140+0.59940
  • 420+4.65754420+0.58275
  • 700+4.61318700+0.57720
  • 1400+4.524471400+0.56610
  • 2800+4.435752800+0.55500
SJ1-3524NG
  • 160+4.77996
  • 320+4.68415
  • 480+4.59042
库存:1090
SJ1-3524NG
    • 140+4.83497140+0.60495
    • 420+4.70190420+0.58830
    • 700+4.65754700+0.58275
    • 1400+4.613181400+0.57720
    • 2800+4.480112800+0.56055
    SJ1-3524NG
      • 1+11.63160
      • 10+9.88200
      • 30+8.78040
      • 100+7.65720
      库存:127
