Additional Resources:
Product Page
3D Model
date
11/21/2022
page 1 of 3
SERIES: RCJ-22 | DESCRIPTION: RCA JACK
FEATURES
• through hole
• mounting tab
• metal bushing
PART NUMBER KEY
RCJ-22 X X
X1
Base Number
Input X1
Input X2
X2
Input Color Options
1 = black
2 = red
3 = white
4 = yellow
5 = blue
6 = green
Example part number: RCJ-2221
input 1 = red
input 2 = black
SPECIFICATIONS
parameter
conditions/description
min
insulation resistance
at 500 Vdc
100
voltage withstand
for 1 minute
typ
contact resistance
units
30
mΩ
MΩ
500
life
RoHS
max
5,000
yes
cuidevices.com
Vac
cycles
Product Page
3D Model
CUI DEVICES | SERIES: RCJ-22 | DESCRIPTION: RCA JACK
date 11/21/2022 | page 2 of 3
MECHANICAL DRAWING
units: mm[inches]
TOLERANCE:
±0.3mm (unless otherwise specified)
8.3 0.327
(2 PLCS)
PLATING
brass
nickel
center terminal (2, 3)
brass
tin
insulator (X1, X2)
PBT
housing
ABS
black
cover
ABS
black
16.0 0.630
6.0 0.236
(2 PLCS)
7.8 0.307
(2 PLCS)
MATERIAL
barrel terminal (1)
9.0 0.354
3
10.2 0.402
(2 PLCS)
3.0 0.118
27.4 1.079
14.0 0.551
2.5 0.098
2
3.5 0.138
(2 PLCS)
3
1
2
4.0 0.157
(2 PLCS)
7.0 0.276
10.25 0.404
8.0 0.315
11.5 0.453
5.0 0.197
(3 PLCS)
16.0 0.630
16.8 0.661
7.0 0.276
7.5 0.295
1
10.25 0.404
2
1.7X3.0
(2 PLCS)
1.2 0.047
(3 PLCS)
11.5 0.453
3
4.0 0.157
8.0 0.315
16.2 0.638
PCB LAYOUT
TOP VIEW
Model No.
Schematic
cuidevices.com
RCJ-22XX
1
3
2
Product Page
3D Model
date 11/21/2022 | page 3 of 3
REVISION HISTORY
rev.
description
date
1.0
initial release
06/29/2007
1.01
plating on terminals 1 & 2 changed from silver to tin
08/03/2010
1.02
added mounting hole dimension
11/05/2010
1.03
brand update
06/11/2020
1.04
logo, datasheet style update
11/21/2022
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate
and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may
result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A
critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life
support device or system, or to affect its safety or effectiveness.
cuidevices.com
很抱歉,暂时无法提供与“RCJ-2221”相匹配的价格&库存,您可以联系我们找货
