RCJ-2123
RCJ-2123
    CUIDEVICES
    CONN RCA JACK MONO 3.2MM R/A
RCJ-2123 数据手册
Additional Resources: Product Page | 3D Model date 11/22/2022 page 1 of 3 SERIES: RCJ-21 | DESCRIPTION: RCA JACK FEATURES • through hole • mounting tab • 2 ports PART NUMBER KEY RCJ-21 X X X1 Base Number Input X1 X2 Input X2 Input Color Options 1 = black 2 = red 3 = white 4 = yellow 5 = blue 6 = green Example part number: RCJ-2121 input 1 = red input 2 = black SPECIFICATIONS parameter conditions/description min insulation resistance at 500 Vdc 100 voltage withstand for 1 minute typ contact resistance life yes mΩ 70 5,000 UL94V-0 30 MΩ -25 RoHS units 500 operating temperature flammability rating max cuidevices.com Vac °C cycles Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: RCJ-21 | DESCRIPTION: RCA JACK date 11/22/2022 | page 2 of 3 MECHANICAL DRAWING units: mm[inches] TOLERANCE: ±0.3mm (unless otherwise specified) X1 MATERIAL PLATING barrel terminal (1, 3) bronze nickel center terminal (2, 4) bronze tin insulator (X1, X2) PBT housing ABS X2 27.40 1.079 3.50 0.138 0.10 (2 PLCS) 26.60 1.047 7.20 0.283 0.30 0.012 2.50 0.098 14.00 0.551 8.30 0.327 20.20 0.795 16.70 0.657 10.20 0.402 7.70 0.303 4.50 0.177 (2 PLCS) 4.10 0.161 1.50 0.059 7.80 0.307 5.50 0.217 10.25 0.404 1.00 0.039 (2 PLCS) 2.00 0.079 (2 PLCS) 2.00 0.079 (2 PLCS) 11.00 0.433 3.00 0.118 25.90 1.020 24.30 0.957 14.00 0.551 5.50 0.217 (4 PLCS) 2.50X4.20 (2 PLCS) 3 1 4 10.25 0.404 (2 PLCS) 2 3.00 0.118 11.00 0.433 PCB LAYOUT TOP VIEW 2.50 0.098 (2 PLCS) 1.20 0.047 (2 PLCS) cuidevices.com Model No. Schematic RCJ-21XX 1 2 X1 4 X2 3 Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: RCJ-21 | DESCRIPTION: RCA JACK date 11/22/2022 | page 3 of 3 REVISION HISTORY rev. description date 1.0 initial release 06/13/2007 1.01 new template applied 06/07/2012 1.02 brand update 06/11/2020 logo, datasheet style update 11/22/2022 1.03 The revision history provided is for informational purposes only and is believed to be accurate. CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website. CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use. CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness. cuidevices.com
RCJ-2123 价格&库存
很抱歉,暂时无法提供与“RCJ-2123”相匹配的价格&库存,您可以联系我们找货
RCJ-2123
  • 336+10.91567336+1.36530
  • 672+10.82693672+1.35420
  • 1008+10.738181008+1.34310
  • 1344+10.687531344+1.33677
  • 1680+10.560691680+1.32090
RCJ-2123
  • 336+10.64944336+1.33200
  • 672+10.56069672+1.32090
  • 1008+10.471951008+1.30980
  • 1344+10.422551344+1.30363
  • 1680+10.294461680+1.28760
RCJ-2123
    • 1+25.43400
    • 10+21.80520
    • 30+19.64520
    库存:50
