Additional Resources:
Product Page
3D Model
date
10/11/2019
page
1 of 2
MODEL: SP-35401 │ DESCRIPTION: 3.5 MM STEREO PLUG
FEATURES
• 4 conductor
• modular strain relief
RoHS
SPECIFICATIONS
parameter
conditions/description
min
typ
contact resistance
insulation resistance
at 500 Vdc
voltage withstand
at 50/60Hz for 1 minute
units
30
mΩ
500
Vac
70
°C
100
operating temperature
MΩ
-25
RoHS
max
yes
MECHANICAL DRAWING
units: mm[inches]
tolerance: ±0.3mm
unless otherwise specified
0.40 0.016
0.10
1.00 0.039
3.20 0.126
0.10
0.40 0.016
0.10
9.00 0.354
0.10
3.50 0.138
0.05
14.00 0.551
RING 2
RING 1
3.00 0.118
0.05
nickel
insulator
ABS
black color
ring (1)
brass
nickel
ring (2)
brass
nickel
sleeve
brass
nickel
earth terminal
brass
nickel
body
PVC or TPR
black color
1.00 0.039
0.20
M8x0.75
0.70 0.028
(3 PLCS) 0.10
R0.2 0.008
0.1
3.20 0.126
8.50 0.335
0.20
Note:
PLATING
brass
52.50 2.067
1.00 0.039
2.50 0.098
0.10
MATERIAL
tip
5.50 0.217
0.20
1. All specifications measured at 10~35°C with a relative humidity of 45~85% under standard atmospheric pressure unless otherwise specified.
cuidevices.com
Product Page
CUI Devices │ MODEL: SP-35401 │ DESCRIPTION: 3.5 MM STEREO PLUG
3D Model
date 10/11/2019 page 2 of 2
REVISION HISTORY
rev.
description
date
1.0
initial release
05/05/2011
1.01
body material changed to TPR
08/30/2013
1.02
brand update
10/11/2019
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no
responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any
component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or
effectiveness.
cuidevices.com
很抱歉,暂时无法提供与“SP-35401”相匹配的价格&库存,您可以联系我们找货
