8
7
6
5
4
3
2
1
F
F
HOUSING
SHOWN WITH
COVER ASSEMBLED
HOUSING
TIP SHUNT
SPRING
E
E
COVER
SEE NOTE 4
TIP SPRING
TIP SPRING
SLEEVE SPRING
SLEEVE SPRING
1.34
T
T
TB
S
S
2 CONDUCTOR SINGLE OPEN CIRCUIT
CL
2 CONDUCTOR SINGLE CLOSED CIRCUIT
SN37A12A
SN37A11
D
0.615±0.010
0.254 REF
D
DIM "B"
SEE NOTE 2
0.25
DIM "A"
SEE NOTE 2
R0.030 REF
0.15
SEE NOTE 2
0.025
SEE NOTE 2
0.208
C
HOUSING
TIP SHUNT
SPRING
RING SHUNT
SPRING
0.118±0.020
SEE NOTE 2
SN37A14B
SHOWN
WITH COVER
UNASSEMBLED
HOUSING
1.162
C
0.700
0.057
TYP
0.762
0.500
0.300
RING SPRING
SLEEVE SPRING
TIP SPRING
TIP SPRING
RING SPRING
CL
0.390
T
S
3 CONDUCTOR DOUBLE OPEN CIRCUIT
0.433
CL
0.390
TB
0.128
TYP
0.500
RB
RECOMMENDED
PC BOARD LAYOUT
COMPONENT SIDE
0.462
SN37A14B
CUSTOMER DRAWING
NOTES:
1. MAY BE USED WITH PC BOARD THICKNESSES
RANGING FROM 0.054 - 0.070.
2. THESE DIMENSIONS VARY DEPENDING ON PCB THICKNESS.
DIMENSIONS SHOWN ARE FREE STATE AS SHIPPED.
A
S
B
3 CONDUCTOR DOUBLE CLOSED CIRCUIT
SN37A12B
R
0.187
R
RB
T
TB
S
R
B
SLEEVE SPRING
T
0.187
3. MATERIAL SPECIFICATIONS:
HOUSING - THERMOPLASTIC, BLACK
SPRINGS - SPECIAL COPPER ALLOY, TINNED
COVER - THERMOPLASTIC, BLACK
4. COVER SHIPPED ASSEMBLED ON ALL PART NUMBERS.
PART
NUMBER
DIM "A"
DIM "B"
FREE
STATE
WITH 0.062
THICK PCB
FREE
STATE
WITH 0.062
THICK PCB
SN37A11
0.387
0.375
0.604
0.592
SN37A12A
0.387
0.375
0.604
0.592
SN37A12B
0.387
0.375
0.604
0.592
SN37A14B
0.387
0.375
0.604
THIS DRAWING DESCRIBES A DESIGN CONSIDERED PROPRIETARY IN NATURE, DEVELOPED AND MANUFACTURED
BY SWITCHCRAFT INC. AND IS RELEASED ON A CONFIDENTIAL BASIS FOR IDENTIFICATION PURPOSES ONLY.
UNLESS OTHERWISE SPECIFIED
5. THESE PRODUCTS ARE RoHS COMPLIANT.
REV
ECO NUMBER
11/17/14
DATE
REVISIONS
8
7
6
5
- TWO PLACE DECIMALS
0.02
- THREE PLACE DECIMALS
0.005
0.592
F
4
PC
BY
MULT
DATE DRAWN
BY
10/01/94
ES
DO NOT SCALE DRAWING
SolidWorks CAD File
NAME
C
LBS/M
TEMPER
MATERIAL
SPEC No.
FIRST USED ON
TJK
APVD
WIDTH
FINISH
1. ALL DIMENSIONS IN INCHES
CAD REDRAW WAS
REV A - ECO #27409
SIZE
A
SPEC No.
SCALE
CHKD
ES
10/05/94
3:1
APVD
GHJ
10/05/94
PHONE JACK
INSULATED BUSHING
SHEET
PART No.
1
OF
SN37A SERIES
1
REV
F
很抱歉,暂时无法提供与“SN37A12A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+38.507981+4.98160
- 10+32.7456610+4.23615
- 25+30.6877025+3.96993
- 50+29.2221050+3.78033
- 100+27.82703100+3.59986
- 300+25.75097300+3.33128
- 500+24.83964500+3.21339
- 1000+23.654591000+3.06009
- 2500+22.175082500+2.86869
