SJ1-42514-SMT-TR
SJ1-42514-SMT-TR
    CUIDEVICES
    CONN AUDIO JACK 4COND 2.5MM SMD
SJ1-42514-SMT-TR 数据手册
Additional Resources: Product Page date 08/18/2022 page 1 of 4 SERIES: SJ1-4251X-SMT | DESCRIPTION: AUDIO JACK FEATURES • right angle • plastic bushing • gold flash PART NUMBER KEY SJ1 - 4251 X - SMT - TR Base Number Notes: Switch Options: 4* = no switch 5TS* = tip switch 5RS* = ring switch 6 = tip and ring switch Package Style: SMT = surface mount Packaging: TR = Tape & Reel *Discontinued models SJ1-42515TS-SMT-TR, SJ1-42515RS-SMT-TR & SJ1-42514-SMT-TR SPECIFICATIONS parameter conditions/description min rated input voltage typ max 12 rated input current contact resistance1 between terminal and mating plug between terminal in a closed circuit insulation resistance at 500 Vdc voltage withstand for 1 minute Vdc 1 A 50 30 mΩ mΩ 500 Vac kg 100 MΩ insertion/withdrawal force 0.3 3 operating temperature -25 85 life at a rate of 24 cycles/minute flammability rating UL94V-0 RoHS yes Note: 5,000 1. When measured at a current of less than 100 mA/1 kHz 2. All specifications measured at 10~35°C, humidity at 45~85%, under standard atmospheric pressure, unless otherwise noted. cuidevices.com units °C cycles Additional Resources: Product Page CUI DEVICES | SERIES: SJ1-4251X-SMT | DESCRIPTION: AUDIO JACK date 08/18/2022 | page 2 of 4 MECHANICAL DRAWING units: mm[inches] TOLERANCE: X.X ±0.2mm X.XX ±0.1mm X.XXX ±0.05mm 10.0 0.39 MATERIAL PLATING terminal 1 copper alloy gold terminal 2 copper alloy gold terminal 3 copper alloy gold terminal 4 copper alloy gold terminal 5 brass gold terminal 6 brass gold plastic PA6T or equivalent 2.600 0.10 4.50 0.18 12.0 0.47 4.00 0.16 4.00 0.16 0.10 0.00 (TYP) 2.00 0.08 0.55 0.02 (TYP) 2.00 0.08 0.75 0.03 (TYP) 7.5 0.30 4.0 0.16 3.00 0.12 1.00 0.04 (6 PLCS) 1.8 0.07 1.5 0.0 [0.06] - 0.1 (2 PLCS) 1 5 2 12.0 0.47 0.3 9.0 0.35 4 6 3 2.8 0.11 5.00 0.20 5.5 0.22 7.5 0.30 PCB LAYOUT TOP VIEW Model No. SJ1-42514-SMT Schematic SJ1-42515TS-SMT SJ1-42515RS-SMT 1 4 3 1 4 3 1 4 3 6 2 5 2 SJ1-42516-SMT 1 4 3 6 5 2 2 PIN 1 11 Ø 2.5 MATING PLUG sleeve sleeve sleeve sleeve 2 tip tip tip tip 3 ring 1 ring 1 ring 1 ring 1 4 ring 2 ring 2 ring 2 ring 2 5 NP tip switch NP tip switch 6 NP NP ring switch ring switch cuidevices.com Additional Resources: Product Page CUI DEVICES | SERIES: SJ1-4251X-SMT | DESCRIPTION: AUDIO JACK date 08/18/2022 | page 3 of 4 SOLDERABILITY parameter conditions/description reel storage at relative humidity
SJ1-42514-SMT-TR 价格&库存
很抱歉,暂时无法提供与“SJ1-42514-SMT-TR”相匹配的价格&库存,您可以联系我们找货
