Additional Resources:
Product Page
3D Model
PCB Footprint
date
06/11/2020
page
1 of 3
SERIES: RCJ-05 │ DESCRIPTION: RCA JACK
FEATURES
• through hole
• 2 conductors, 2 contacts
PART NUMBER KEY
RCJ-05 X
Base Number
Housing Color:
1 = Black
2 = Red
3 = White
4 = Yellow
5 = Blue
6 = Green
7 = Orange
SPECIFICATIONS
parameter
conditions/description
min
typ
contact resistance
insulation resistance
at 500 Vdc
voltage withstand
for 1 minute
max
units
30
mΩ
500
Vac
100
life
MΩ
5,000
operating temperature
-20
flammability rating
UL94V-0
RoHS
yes
cuidevices.com
cycles
85
°C
Product Page
3D Model
PCB Footprint
CUI Devices │ SERIES: RCJ-05 │ DESCRIPTION: RCA JACK
date 06/11/2020│ page 2 of 3
MECHANICAL DRAWING
units: mm
tolerance: ±0.3 mm
MATERIAL
PLATING
terminal 1
brass
nickel
terminal 2
brass
tin
housing
PA66
nickel
3.50 0.138
19.50 0.768
10.00 0.394
1.40 0.055
10.00 0.394
4.00 0.157
5.00 0.197
13.00 0.512
1.80 0.071
3.30 0.130
8.30 0.327
11.50 0.453
5.40 0.213
3.30 0.130
4.00 0.157
1.00X2.50
2
3.30 0.130
5.40 0.213
1
1.30X2.50
Recommended PCB Layout
Top View
Model No.
RCJ-05
2
Schematic
cuidevices.com
1
Product Page
3D Model
PCB Footprint
date 06/11/2020│ page 3 of 3
REVISION HISTORY
rev.
description
date
1.0
initial release
04/11/2006
1.01
title corrected from right angle to vertical
05/11/2009
1.02
brand update
06/11/2020
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no
responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any
component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or
effectiveness.
cuidevices.com
很抱歉,暂时无法提供与“RCJ-051”相匹配的价格&库存,您可以联系我们找货
