RCJ-053
RCJ-053
    CUIDEVICES
    CONN RCA JACK MONO 3.2MM PCB
RCJ-053 数据手册
Additional Resources: Product Page | 3D Model | PCB Footprint date 06/11/2020 page 1 of 3 SERIES: RCJ-05 │ DESCRIPTION: RCA JACK FEATURES • through hole • 2 conductors, 2 contacts PART NUMBER KEY RCJ-05 X Base Number Housing Color: 1 = Black 2 = Red 3 = White 4 = Yellow 5 = Blue 6 = Green 7 = Orange SPECIFICATIONS parameter conditions/description min typ contact resistance insulation resistance at 500 Vdc voltage withstand for 1 minute max units 30 mΩ 500 Vac 100 life MΩ 5,000 operating temperature -20 flammability rating UL94V-0 RoHS yes cuidevices.com cycles 85 °C Additional Resources: Product Page | 3D Model | PCB Footprint CUI Devices │ SERIES: RCJ-05 │ DESCRIPTION: RCA JACK date 06/11/2020│ page 2 of 3 MECHANICAL DRAWING units: mm tolerance: ±0.3 mm MATERIAL PLATING terminal 1 brass nickel terminal 2 brass tin housing PA66 nickel 3.50 0.138 19.50 0.768 10.00 0.394 1.40 0.055 10.00 0.394 4.00 0.157 5.00 0.197 13.00 0.512 1.80 0.071 3.30 0.130 8.30 0.327 11.50 0.453 5.40 0.213 3.30 0.130 4.00 0.157 1.00X2.50 2 3.30 0.130 5.40 0.213 1 1.30X2.50 Recommended PCB Layout Top View Model No. RCJ-05 2 Schematic cuidevices.com 1 Additional Resources: Product Page | 3D Model | CUI Devices │ SERIES: RCJ-05 │ DESCRIPTION: RCA JACK PCB Footprint date 06/11/2020│ page 3 of 3 REVISION HISTORY rev. description date 1.0 initial release 04/11/2006 1.01 title corrected from right angle to vertical 05/11/2009 1.02 brand update 06/11/2020 The revision history provided is for informational purposes only and is believed to be accurate. CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website. CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use. CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness. cuidevices.com
RCJ-053 价格&库存
很抱歉,暂时无法提供与“RCJ-053”相匹配的价格&库存,您可以联系我们找货
RCJ-053
  • 1+11.654151+1.46146
  • 10+9.8996710+1.24144
  • 25+9.2762825+1.16327
  • 50+8.8313050+1.10747
  • 100+8.40995100+1.05463
  • 400+7.62556400+0.95626
  • 800+7.26142800+0.91060
  • 1200+7.056661200+0.88492
  • 2800+6.647242800+0.83358
库存:3007
RCJ-053
    • 10+6.6829210+0.83805
    • 40+6.5058940+0.81585
    • 125+6.32885125+0.79365
    • 400+6.15182400+0.77145
    • 1250+5.842021250+0.73260
    库存:4400
    RCJ-053
    • 800+5.88628800+0.73815
    • 1600+5.797761600+0.72705
    • 2400+5.709252400+0.71595
