SJ-3506-SMT-TR
SJ-3506-SMT-TR
    CUIDEVICES
    CONN JACK 3.5MM R/A STEREO SMD
SJ-3506-SMT-TR 数据手册
Additional Resources: Product Page | 3D Model | PCB Footprint date 10/08/2019 page 1 of 4 MODEL: SJ-3506-SMT-TR │ DESCRIPTION: MID MOUNT AUDIO JACK FEATURES • mid mount for low profile applications • shielded • two switch configuration, one normally open, one isolated and normally closed SPECIFICATIONS parameter conditions/description min typ rated input voltage rated input current contact resistance1 between terminal and mating plug between terminal in a closed circuit insulation resistance at 500 Vdc voltage withstand for 1 minute 1 A 50 30 mΩ mΩ MΩ 0.3 operating temperature -25 life at a rate of 24 cycles/minute flammability rating UL94V-0 RoHS yes units Vdc 100 insertion/withdrawal force Note: max 12 500 Vac 3 kg 85 5,000 °C cycles 1. When measured at a current of less than 100 mA/1 kHz 2. All specifications measured at 10~35°C, humidity at 45~85%, under standard atmospheric pressure, unless otherwise noted. SOLDERABILITY parameter conditions/description reel storage min at relative humidity
SJ-3506-SMT-TR 价格&库存
很抱歉,暂时无法提供与“SJ-3506-SMT-TR”相匹配的价格&库存,您可以联系我们找货
