PJRAN1X1U02X
PJRAN1X1U02X
    SWITCHCRAFT
    PJRAN1X1U02X
PJRAN1X1U02X 数据手册
PART NUMBER INSERT COLOR SHELL AND SLEEVE TERMINAL FINISH PJRAN1X1U01X BLACK NICKEL PLATED PJRAN1X1U01AUX BLACK GOLD PLATED PJRAN1X1U02X WHITE NICKEL PLATED PJRAN1X1U02AUX WHITE GOLD PLATED PJRAN1X1U03X RED NICKEL PLATED PJRAN1X1U03AUX RED GOLD PLATED PJRAN1X1U04X YELLOW NICKEL PLATED PJRAN1X1U04AUX YELLOW GOLD PLATED PJRAN1X1U07X ORANGE NICKEL PLATED NOTES: 1. ALL DIMENSIONS ARE REFERENCE. 2. MATERIALS: B HOUSING: ABS OR PBT, UL-94HB, BLACK OR SAME COLOR AS INSERT. B COLOR INSERT: POM OR PBT, UL-94HB SHELL & SLEEVE TERMINAL: COPPER ALLOY, NICKEL OR GOLD PLATED TIP & SHUNT TERMINALS: COPPER ALLOY, TIN PLATED 2 3 1 SCHEMATIC 3. THIS PART IS RoHS COMPLIANT 0.394 [10,0] 0.158 [4,0] 0.768 [19,5] INSERT 0.133 [3,4] HOUSING 0.374 [9,5] SHELL 0.197 [5,0] 0.059 [1,5] TIP (2) 0.327 [8,3] 0.649 [16,5] 0.315 [8,0] 0.158 [4,0] SHUNT (3) 0.039 X 0.098 [1.0] X [2.5] TYP (2) 0.295 [7,5] 0.082 [2,1] 0.532 [13,5] SLEEVE (1) 0.295 [7,5] 0.146 [3,7] CUSTOMER DRAWING 0.158 [4,0] THIS DRAWING DESCRIBES A DESIGN CONSIDERED PROPRIETARY IN NATURE, DEVELOPED AND MANUFACTURED BY SWITCHCRAFT INC. AND IS RELEASED ON A CONFIDENTIAL BASIS FOR IDENTIFICATION PURPOSES ONLY. STAR SYMBOL DENOTES CRITICAL DIMENSION UNLESS OTHERWISE SPECIFIED 1. ALL DIMENSIONS IN INCHES -TWO PLACE DECIMALS 0.01 -THREE PLACE DECIMALS 0.005 -ANGLES 1 -ALL DIA. CONCENTRIC WITHIN 0.005 T.I.R. 0.098 x 0.051 [2.5] x [1.3] 0.079 [2,0] P.C. BOARD LAYOUT COMPONENT SIDE 0.158 [4,0] B 27929 08-17-17 PC TJK 2. FEATURES ON THE SAME CENTERLINE MUST BE ALIGNED WITHIN 0.002 A 25181 1-13-06 JL TJK 3. REMOVE ALL BURRS REV ECO NUMBER DATE BY APVD REVISIONS SIZE MULT FINISH SCALE DATE DRAWN BY CHKD 13-Jan-06 JL TJK 1-13-06 3:1 APVD TJK 1-13-06 PHONO JACK - RIGHT ANGLE 1 POS, PC MOUNT, UNSHIELDED, RoHS B TEMPER SPEC No. FIRST USED ON DO NOT SCALE DRAWING LBS/M MATERIAL SPEC No. NAME Pro/Engineer CAD File WIDTH SHEET 1 OF 1 PART No. PJRAN1X1U__X SERIES REV B
PJRAN1X1U02X 价格&库存
很抱歉,暂时无法提供与“PJRAN1X1U02X”相匹配的价格&库存,您可以联系我们找货
PJRAN1X1U02X
  • 1+13.510621+1.74781
  • 10+11.4995210+1.48764
  • 25+10.7824425+1.39488
  • 50+10.2648750+1.32792
  • 100+9.77475100+1.26452
  • 250+9.16236250+1.18529
  • 500+8.72479500+1.12869
  • 1000+8.308341000+1.07481
  • 2500+7.788322500+1.00754
库存:1002
