Additional Resources:
Product Page
3D Model
PCB Footprint
date
10/09/2019
page
1 of 3
SERIES: SJ1-351XN │ DESCRIPTION: 3.5 MM AUDIO JACK
FEATURES
• right angle
• non-threaded
• metal bushing
PART NUMBER KEY
SJ1 - 351 X N
Base Number
Switch Options:
3 = no switch
4 = tip switch
5 = tip and ring switch
SPECIFICATIONS
parameter
conditions/description
min
rated input voltage
typ
12
rated input current
contact resistance1
between terminal and mating plug
between terminal in a closed circuit
insulation resistance
at 500 Vdc
voltage withstand
at 50/60 Hz for 1 minute
any direction for 10 seconds
-25
life
A
mΩ
mΩ
500
Vac
3
kg
500
g
85
°C
5,000
flammability rating
UL94V-0
RoHS
yes
Notes:
1
50
30
MΩ
0.3
operating temperature
units
Vdc
100
insertion/withdrawal force
terminal strength
max
cycles
1. When measured at a current of less than 100 mA / 1 kHz
SOLDERABILITY
parameter
min
typ
max
units
wave soldering
dipped in solder pot for 5±0.5 seconds at
255
260
265
°C
cuidevices.com
Product Page
3D Model
PCB Footprint
CUI Devices │ SERIES: SJ1-351XN │ DESCRIPTION: 3.5 MM AUDIO JACK
date 10/09/2019 │ page 2 of 3
MECHANICAL DRAWING
units: mm[inches]
TOLERANCE:
X.X ±0.2mm
X.XX ±0.1mm
X.XXX ±0.05mm
MATERIAL
PLATING
terminal 1
brass
silver
terminal 2
brass
silver
terminal 3
brass
silver
terminal 4
brass
silver
terminal 5
brass
silver
bushing
brass
nickel
spring
stainless steel
cover
PBT
plastic
PBT
11.5 0.453
1.00 0.039
5.95 0.234
3.50 0.138
14.0 0.551
6.0 0.236
6.0 0.236
3.600 0.142
3.0 0.118
(TYP) 0.3
1.30 0.051
(TYP)
12.9 0.508
5.3 0.209
1.8 0.071
2
5
4
4.2 0.165
4.5 0.177
1
2.5 0.098
5
5.0 0.197
3
4
8.4 0.331
10.1 0.398
PCB LAYOUT
TOP VIEW
Model No.
SJ1-3513N
SJ1-3514N
SJ1-3515N
1
3
1
3
2
4
2
1
3
5
4
2
Schematic
1
3
2
PIN
14
Ø3.5 MATING PLUG
1
sleeve
sleeve
sleeve
2
tip
tip
tip
3
ring
ring
ring
4
NP
tip switch
tip switch
5
NP
NP
ring switch
cuidevices.com
Product Page
3D Model
PCB Footprint
date 10/09/2019 │ page 3 of 3
REVISION HISTORY
rev.
description
date
1.0
initial release
09/06/2006
1.01
new template applied
02/07/2012
1.02
changed top cover to PBT
04/19/2017
1.03
changed terminal plating to silver
02/12/2019
brand update
10/09/2019
1.04
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no
responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any
component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or
effectiveness.
cuidevices.com
很抱歉,暂时无法提供与“SJ1-3514N”相匹配的价格&库存,您可以联系我们找货
