Additional Resources:
Product Page
date
01/31/2020
page
1 of 3
SERIES: SJ1-4251X │ DESCRIPTION: AUDIO JACK
FEATURES
• low profile design
• switch options include:
– no switch
– tip switch
– ring switch
– tip and ring switch
RoHS
PART NUMBER KEY
SJ1 - 4251 X
Base Number
Switch Options
4 = no switch
5TS = tip switch
5RS = ring switch
6 = tip and ring switch
SPECIFICATIONS
parameter
conditions/description
min
rated input voltage
typ
12
rated input current
contact resistance
between terminal and mating plug
between terminal in a closed circuit*
insulation resistance
at 500 Vdc
voltage withstand
at 50/60Hz for 1 minute
0.3
-25
life
A
50
30
mΩ
mΩ
500
Vac
3
kg
500
g
85
5,000
RoHS
Notes:
Vdc
MΩ
any direction for 10 seconds
operating temperature
units
1
100
insertion/withdrawal force
terminal strength
max
°C
cycles
yes
*When measured at a current of less than 100 mA / 1 kHz
SOLDERABILITY
parameter
min
typ
max
units
wave soldering
dipped in solder pot for 5±0.5 seconds at
255
260
265
°C
cuidevices.com
Product Page
CUI Devices │ SERIES: SJ1-4251X │ DESCRIPTION: AUDIO JACK
date 01/31/2020│ page 2 of 3
MECHANICAL DRAWING
units: mm[inches]
TOLERANCE:
X.X ±0.2mm
X.XX ±0.1mm
X.XXX ±0.05mm
10.0 0.394
MATERIAL
PLATING
terminal 1
copper alloy
gold flash
terminal 2
copper alloy
gold flash
terminal 3
copper alloy
gold flash
terminal 4
copper alloy
gold flash
terminal 5
brass
gold flash
terminal 6
brass
gold flash
plastic
PA66
2.00 0.079
4.50 0.177
10.0 0.394
4.00 0.157
2.600 0.102
4.00 0.157
2.00 0.079
4.00 0.157
0.8 0.031
(TYP)
1.00 0.039
(6 PLCS)
2.8 0.110
2.5 0.098
5.5 0.217
7.5 0.295
5.5 0.217
2.8 0.110
1.6 0.063
+0.1
-0.0
(2 PLCS)
1.5 0.059
+0.0
-0.1
(2 PLCS)
7.5 0.295
4
6
4.0 0.157
0.80X1.50
(6 PLCS)
3
1.8 0.071
1
4.0 0.157
3.00 0.118
4.7 0.185
1
5
2
2
5
4.7 0.185
5.00 0.197
3.6 0.142
9.0 0.354
7.2 0.283
7.2 0.283
4.0 0.157
6
4
3.6 0.142
1.8 0.071
3
5.00 0.197
3.00 0.118
4.0 0.157
7.5 0.295
Model No.
SJ1-42514
PCB LAYOUT
TOP VIEW
Schematic
SJ1-42515TS
SJ1-42515RS
1
4
3
1
4
3
2
5
2
SJ1-42516
1
4
3
6
1
4
3
6
5
2
2
PIN
11
Ø 2.5 MATING PLUG
1
sleeve
sleeve
sleeve
sleeve
2
tip
tip
tip
tip
3
ring 1
ring 1
ring 1
ring 1
4
ring 2
ring 2
ring 2
ring 2
5
NP
tip switch
NP
tip switch
6
NP
NP
ring switch
ring switch
cuidevices.com
Product Page
date 01/31/2020│ page 3 of 3
REVISION HISTORY
rev.
description
date
1.0
initial release
10/27/2005
1.01
new template applied
12/15/2011
1.02
brand update
01/31/2020
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no
responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any
component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or
effectiveness.
cuidevices.com
很抱歉,暂时无法提供与“SJ1-42516”相匹配的价格&库存,您可以联系我们找货
