RCP-024
RCP-024
    CUIDEVICES
    CONN RCA PLUG MONO 2COND
RCP-024 数据手册
Additional Resources: Product Page date 06/11/2020 page 1 of 3 SERIES: RCP-02 │ DESCRIPTION: RCA PLUG FEATURES • modular RCA plug connector • available in multiple colors PART NUMBER KEY RCP-02 X Base Number Color Options 1 = black 2 = red 3 = white 4 = yellow 5 = blue 6 = green 7 = orange SPECIFICATIONS parameter conditions/description min insulation resistance at 500 Vdc 100 voltage withstand for 1 minute typ contact resistance operating temperature 5,000 flammability UL94HB RoHS yes cuidevices.com units 30 mΩ MΩ -20 life max 500 Vac 85 °C cycles Additional Resources: Product Page CUI Devices │ SERIES: RCP-02 │ DESCRIPTION: RCA PLUG date 06/11/2020│ page 2 of 3 MECHANICAL DRAWING units: mm[inches] tolerance: ±0.3 mm unless otherwise specified 3.2 0.126 9.0 0.354 51.5 2.028 MATERIAL PLATING barrel brass nickel cover PE color barrel housing ABS color 10.7 0.421 11.9 0.469 11.7 0.461 8.2 0.323 6.3 0.248 24.0 0.945 cuidevices.com 5.0 0.197 6.4 0.252 Additional Resources: Product Page CUI Devices │ SERIES: RCP-02 │ DESCRIPTION: RCA PLUG date 06/11/2020│ page 3 of 3 REVISION HISTORY rev. description date 1.0 initial release 05/16/2006 1.01 brand update 06/11/2020 The revision history provided is for informational purposes only and is believed to be accurate. CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website. CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use. CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness. cuidevices.com
RCP-024 价格&库存
很抱歉,暂时无法提供与“RCP-024”相匹配的价格&库存,您可以联系我们找货
RCP-024
  • 1+15.674091+1.96632
  • 10+13.3123810+1.67005
  • 25+12.4782725+1.56541
  • 50+11.8809650+1.49047
  • 100+11.31256100+1.41917
  • 300+10.46825300+1.31325
  • 500+10.09763500+1.26675
  • 1000+9.615681000+1.20629
  • 2500+9.013972500+1.13081
库存:745
