RCJ-032
RCJ-032
    CUIDEVICES
    CONN RCA JACK METAL RED PNL MNT
RCJ-032 数据手册
Additional Resources: Product Page | 3D Model date 06/11/2020 page 1 of 3 SERIES: RCJ-03 │ DESCRIPTION: RCA JACK FEATURES • through hole • 2 conductors, 2 contacts PART NUMBER KEY RCJ-03 X Base Number Housing Color: 1 = Black 2 = Red 3 = White 4 = Yellow 5 = Blue 6 = Green 7 = Orange SPECIFICATIONS parameter conditions/description min typ contact resistance insulation resistance at 500 Vdc voltage withstand for 1 minute RoHS yes 30 mΩ 500 Vac MΩ 5,000 UL94V-0 units 100 life flammability rating max cuidevices.com cycles Additional Resources: Product Page | 3D Model CUI Devices │ SERIES: RCJ-03 │ DESCRIPTION: RCA JACK date 06/11/2020│ page 2 of 3 MECHANICAL DRAWING units: mm tolerance: ±0.3 mm MATERIAL PLATING terminal 1 brass nickel terminal 2 brass nickel shell brass nickel nut brass nickel insulator PBT bushing PBT 21.50 0.847 15.8 0.622 11.10 0.437 8.95 0.352 6.10 0.240 1.30 0.051 9.5 0.374 8.3 0.327 2.00 0.079 1/4-32 3.4 0.134 2.0 0.079 Model No. RCJ-03 2 Schematic cuidevices.com 1 Additional Resources: Product Page CUI Devices │ SERIES: RCJ-03 │ DESCRIPTION: RCA JACK | 3D Model date 06/11/2020│ page 3 of 3 REVISION HISTORY rev. description date 1.0 initial release 04/11/2006 1.01 brand update 06/11/2020 The revision history provided is for informational purposes only and is believed to be accurate. CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website. CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use. CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness. cuidevices.com
RCJ-032 价格&库存
很抱歉,暂时无法提供与“RCJ-032”相匹配的价格&库存,您可以联系我们找货
RCJ-032
    • 1+5.23766
    库存:410
