RN114BPC
RN114BPC
    SWITCHCRAFT
    插件
RN114BPC 数据手册
8 7 6 4 T TS S T F 5 S 3 R R T T TS S S 2 R RS T SCHEMATIC TYPICAL MATING PLUG: 250 TYPICAL MATING PLUG: 250 TYPICAL MATING PLUG: 267 RN111PC RN112APC RN112BPC R RS T TS S S SCHEMATIC SCHEMATIC SCHEMATIC SCHEMATIC 1 TYPICAL MATING PLUG: 267 SCHEMATIC TYPICAL MATING PLUG: 267 TYPICAL MATING PLUG: 267 RN113BPC RN113FPC COVER F RN114BPC SLEEVE SPRING E E TIP SPRING SHUNT SPRING WASHER SEE NOTE 1 HEX NUT SEE NOTE 1 CL 0.625 MAX 15.88 JAX CASE D 0.11 2.7 SHUNT SPRING COVER REMOVED IN THIS VIEW 0.25 6.4 SECTION A-A A 3/8-32 UNEF-2A THREAD TIP SHUNT HOLE TO CLEAR 0.016 [0.40] x 0.050 [1.27] TERMINAL 0.300 7.62 SLEEVE HOLE TO CLEAR 0.012 [0.30] x 0.050 [1.27] TERMINAL 0.69 MAX 17.5 0.025 0.64 0.500 12.70 0.13 3.2 B 0.500 12.70 TIP HOLE TO CLEAR 0.016 [0.40] x 0.050 [1.27] TERMINAL 0.095±0.001 2.41±0.03 (3) POST HOLES CL 0.380 9.65 RN114BPC SHOWN 0.724 18.38 0.28 7.1 C 0.100 2.54 0.500 12.70 B COMPONENT SIDE SCALE 2:1 0.016 TYP 0.40 TIP, RING AND SHUNT TERMINALS CUSTOMER DRAWING 1. HARDWARE SHIPPED UNASSEMBLED. 1.275 MAX 32.39 0.277 7.02 REF THIS DRAWING DESCRIBES A DESIGN CONSIDERED PROPRIETARY IN NATURE, DEVELOPED AND MANUFACTURED BY SWITCHCRAFT INC. AND IS RELEASED ON A CONFIDENTIAL BASIS FOR IDENTIFICATION PURPOSES ONLY. 2. MATERIALS: JAX CASE AND COVER - THERMOPLASTIC, BLACK SPRINGS/TERMINALS - SPECIAL COPPER ALLOY, TIN PLATED WASHER - CRS, NICKEL PLATED HEX NUT - COPPER ALLOY, NICKEL PLATED UNLESS OTHERWISE SPECIFIED 1. ALL DIMENSIONS IN INCHES [mm] 3. THESE PRODUCTS ARE RoHS COMPLIANT. 7 E REV 6 5 - TWO PLACE DECIMALS 0.02 [0.5] - THREE PLACE DECIMALS 0.005 [0.13] SIZE REDRAWN 27712 ECO NUMBER 05-31-16 DATE 4 PC BY TJK APVD DO NOT SCALE DRAWING SolidWorks CAD File WIDTH MULT FINISH TEMPER BY A SPEC No. SCALE CHKD 4:1 APVD TJK JEB 01-06-09 JEB 01-06-09 01-28-09 NAME RN SERIES RIGHT ANGLE "HI-D" JAX, RoHS C LBS/M MATERIAL SPEC No. FIRST USED ON DATE DRAWN REVISIONS 8 RING HOLE TO CLEAR 0.016 [0.40] x 0.050 [1.27] TERMINAL PCB LAYOUT 0.050 [1.27] x 0.012 [0.30] SLEEVE TERMINAL NOTES: 0.98 25.0 C 0.300 7.62 CL RING SHUNT HOLE TO CLEAR 0.016 [0.40] x 0.050 [1.27] TERMINAL 0.16 4.0 A A D 0.324 8.22 0.050 [1.27] TYP TIP, RING AND SHUNT TERMINALS RING SPRING 0.11 2.7 SHEET PART No. 1 OF RN111-RN114 SERIES 1 REV E
RN114BPC 价格&库存
很抱歉,暂时无法提供与“RN114BPC”相匹配的价格&库存,您可以联系我们找货
