Additional Resources:
Product Page
3D Model
PCB Footprint
date
10/04/2019
page
1 of 4
SERIES: SJ1-253X-SMT │ DESCRIPTION: 2.5 MM AUDIO JACK
FEATURES
• low profile design
• switch options include:
– no switch
– tip switch
– tip and ring switch
• suitable for medical applications
PART NUMBER KEY
SJ1-253 X-SMT-TR
Base Number
Switch Options:
3 = no switch
4 = tip switch
5 = tip and ring switch
Packaging:
TR = Tape & Reel
SPECIFICATIONS
parameter
conditions/description
min
rated input voltage
typ
12
rated input current
contact resistance1
between terminal and mating plug
between terminal in a closed circuit
insulation resistance
at 500 Vdc
voltage withstand
for 1 minute
1
A
50
30
mΩ
mΩ
MΩ
0.3
operating temperature
-25
life
at a rate of 24 cycles/minute
flammability rating
UL94V-0
RoHS
yes
500
Vac
3
kg
85
5,000
1. When measured at a current of less than 100 mA/1 kHz
2. All specifications measured at 10~35°C, humidity at 45~85%, under standard atmospheric pressure, unless otherwise noted.
cuidevices.com
units
Vdc
100
insertion/withdrawal force
Note:
max
°C
cycles
Product Page
3D Model
PCB Footprint
CUI Devices │ SERIES: SJ1-253X-SMT │ DESCRIPTION: 2.5 MM AUDIO JACK
date 10/04/2019 │ page 2 of 4
MECHANICAL DRAWING
units: mm[inches]
tolerance:
X.X ±0.2 mm
X.XX ±0.10 mm
X.XXX ±0.050 mm
PCB: ±0.05 mm
7.4 0.291
PLATING
terminal 1
copper alloy
gold flash
terminal 2
copper alloy
gold flash
terminal 3
copper alloy
gold flash
terminal 4
brass
gold flash
terminal 5
copper alloy
gold flash
plastic
PA6T or
equivalent
2.600 0.102
3.60 0.142
10.4 0.409
1.20 0.047
0.30 0.012
3.1 0.122
(TYP)
3.00 0.118
1.35 0.053
MATERIAL
4.6 0.181
(TYP)
4.8 0.189
(TYP)
1.00 0.039
0.50 0.020
(2 PLCS)
5.40 0.213
7.7 0.303
4.7 0.185
1.3 0.051
+0.0
-0.1
1.7 0.067
1.8 0.071
+0.0
-0.1
1
3
5
2
4
3.6 0.142
Recommended PCB Layout
Top View
Model No.
0.80 0.031
(5 PLCS)
10.0 0.394
SJ1-2533-SMT
SJ1-2534-SMT
SJ1-2535-SMT
1
3
1
3
2
4
2
1
3
5
4
2
Schematic
11
Ø 2.5 MATING PLUG
PIN
1
sleeve
sleeve
sleeve
2
tip
tip
tip
3
ring
ring
ring
4
NP
tip switch
tip switch
5
NP
NP
ring swtich
cuidevices.com
Product Page
3D Model
PCB Footprint
date 10/04/2019 │ page 3 of 4
SOLDERABILITY
parameter
reel storage
at relative humidity
很抱歉,暂时无法提供与“SJ1-2534-SMT-TR”相匹配的价格&库存,您可以联系我们找货
