Additional Resources:
Product Page
date
10/04/2019
page
1 of 4
SERIES: SJ2-2592X-SMT │ DESCRIPTION: AUDIO JACK
tip switch or no switch
low profile design
reflow solder compatible
surface mount
N
U
ED
FEATURES
TI
PART NUMBER KEY
SJ2-2592 X X - SMT-TR
Switch Options:
A = no switch
B = tip switch
Package Style:
SMT = surface mount
Packaging:
TR = Tape & Reel
1. 2 conductor option only available with tip switch
O
Note:
# Conductors:
21 = 2
3=3
N
Base Number
SPECIFICATIONS
parameter
min
typ
rated input current
contact resistance2
between terminal and mating plug
between terminal in a closed circuit
insulation resistance
at 500 Vdc
voltage withstand
for 1 minute
-25
life
at a rate of 24 cycles/minute
flammability rating
UL94V-0
RoHS
yes
D
1
A
50
30
mΩ
mΩ
MΩ
0.3
operating temperature
500
Vac
3
kg
85
5,000
2. When measured at a current of less than 100 mA/1 kHz
3. All specifications measured at 10~35°C, humidity at 45~85%, under standard atmospheric pressure, unless otherwise noted.
cuidevices.com
units
Vdc
100
insertion/withdrawal force
Note:
max
12
IS
C
rated input voltage
conditions/description
°C
cycles
Product Page
CUI Devices │ SERIES: SJ2-2592X-SMT │ DESCRIPTION: AUDIO JACK
date 10/04/2019│ page 2 of 4
MECHANICAL DRAWING
PLATING
terminal 1
copper alloy
silver
terminal 2
copper alloy
gold flash
terminal 3
copper alloy
gold flash
terminal 10
brass
gold flash
plastic
PA10T
ED
MATERIAL
N
TI
N
U
units: mm
tolerance:
X.X ±0.2 mm
X.XX ±0.10 mm
X.XXX ±0.050 mm
PCB: ±0.05 mm
IS
C
O
Recommended PCB Layout
Top View
1
3
2
D
11
Ø2.5 MATING PLUG
Model No.
SJ2-25922B-SMT
SJ2-25923A-SMT
1
Schematic
10
2
SJA-25923B-SMT
1
3
1
3
2
10
2
PIN
1
sleeve
sleeve
sleeve
2
tip
tip
tip
3
NP
ring
ring
10
tip switch
NP
tip switch
cuidevices.com
Product Page
date 10/04/2019│ page 3 of 4
SOLDERABILITY
parameter
reel storage
at relative humidity
很抱歉,暂时无法提供与“SJ2-25922B-SMT-TR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+8.542531+1.06529
- 10+7.2845810+0.90842
- 25+6.8280625+0.85149
- 50+6.5023450+0.81087
- 100+6.19216100+0.77219
- 250+5.80394250+0.72378
- 500+5.52663500+0.68920
