SJ2-25313A-SMT-TR
SJ2-25313A-SMT-TR
    CUIDEVICES
    AUDIOJACK,2.5MM,RT,3CONDUC
SJ2-25313A-SMT-TR 数据手册
Additional Resources: Product Page date 10/04/2019 page 1 of 4 SERIES: SJ2-2531X-SMT │ DESCRIPTION: AUDIO JACK gold flash terminal plating multiple switch configurations reflow solder compatible low profile design N U • • • • ED FEATURES TI PART NUMBER KEY SJ2-2531 X X - SMT-TR Switch Options: A = no switch B = tip switch C = ring switch D = tip & ring switch Package Style: SMT = surface mount Packaging: TR = Tape & Reel 1. 2 conductor option only available with tip switch O Note: # Conductors: 21 = 2 3=3 N Base Number SPECIFICATIONS parameter min typ rated input current contact resistance2 between terminal and mating plug between terminal in a closed circuit insulation resistance at 500 Vdc voltage withstand for 1 minute -25 life at a rate of 24 cycles/minute flammability rating UL94V-0 RoHS yes D 1 A 50 30 mΩ mΩ MΩ 0.3 operating temperature 500 Vac 3 kg 85 5,000 2. When measured at a current of less than 100 mA/1 kHz 3. All specifications measured at 10~35°C, humidity at 45~85%, under standard atmospheric pressure, unless otherwise noted. cuidevices.com units Vdc 100 insertion/withdrawal force Note: max 12 IS C rated input voltage conditions/description °C cycles Additional Resources: Product Page CUI Devices │ SERIES: SJ2-2531X-SMT │ DESCRIPTION: AUDIO JACK date 10/04/2019│ page 2 of 4 MECHANICAL DRAWING PLATING terminal 1 copper alloy gold flash terminal 2 copper alloy gold flash terminal 3 copper alloy gold flash terminal 10 brass gold flash terminal 11 copper alloy gold flash plastic PA10T ED MATERIAL IS C O N TI N U units: mm tolerance: X.X ±0.2 mm X.XX ±0.10 mm X.XXX ±0.050 mm PCB: ±0.05 mm 1 3 2 D 11 Ø2.5 MATING PLUG Model No. SJ2-25312B-SMT Recommended PCB Layout Top View SJ2-25313A-SMT 1 Schematic 10 2 SJ2-25313B-SMT 1 3 1 3 2 10 2 SJ2-25313C-SMT SJ2-25313D-SMT 1 3 11 1 3 11 10 2 2 PIN 1 sleeve sleeve sleeve sleeve sleeve 2 tip tip tip tip tip 3 NP ring ring ring ring 10 tip switch NP tip switch NP tip switch 11 NP NP NP ring switch ring switch cuidevices.com Additional Resources: Product Page CUI Devices │ SERIES: SJ2-2531X-SMT │ DESCRIPTION: AUDIO JACK date 10/04/2019│ page 3 of 4 SOLDERABILITY parameter conditions/description reel storage at relative humidity
SJ2-25313A-SMT-TR 价格&库存
很抱歉,暂时无法提供与“SJ2-25313A-SMT-TR”相匹配的价格&库存,您可以联系我们找货
SJ2-25313A-SMT-TR
  • 1300+4.98150
库存:1300
