SJ2-25934B1-SMT-TR
SJ2-25934B1-SMT-TR
    CUIDEVICES
    AUDIOJACK,2.5MM,RT,4CONDUC
SJ2-25934B1-SMT-TR 数据手册
Additional Resources: Product Page date 08/18/2022 page 1 of 4 SERIES: SJ2-2593X-SMT | DESCRIPTION: AUDIO JACK FEATURES • gold flash terminal plating • multiple switch configurations • low profile design • reflow solder compatible PART NUMBER KEY SJ2 - 2593 X X - SMT - TR Base Number Notes: # Conductors: 4= 4 Switch Options: A1*1 = no switch B1*1 = tip switch C11 = ring switch D11 = tip & ring switch D* = tip & ring switch Package Style: SMT = surface mount Packaging: TR = Tape & Reel 1. Additional sleeve contact *Discontinued models SJ2-25934D-SMT-TR, SJ2-25934B1-SMT-TR, & SJ2-25934A1-SMT-TR SPECIFICATIONS parameter conditions/description min rated input voltage typ rated input current contact resistance2 between terminal and mating plug between terminal in a closed circuit insulation resistance at 500 Vdc voltage withstand for 1 minute -25 life at a rate of 24 cycles/minute flammability rating UL94V-0 RoHS yes 1 A 50 30 mΩ mΩ MΩ 0.3 operating temperature cuidevices.com 500 Vac 3 kg 85 5,000 2. When measured at a current of less than 100 mA/1 kHz 3. All specifications measured at 10~35°C, humidity at 45~85%, under standard atmospheric pressure, unless otherwise noted. units Vdc 100 insertion/withdrawal force Note: max 12 °C cycles Additional Resources: Product Page CUI DEVICES | SERIES: SJ2-2593X-SMT | DESCRIPTION: AUDIO JACK date 08/18/2022 | page 2 of 4 MECHANICAL DRAWING units: mm tolerance: X.X ±0.2 mm X.XX ±0.10 mm X.XXX ±0.050 mm PCB: ±0.05 mm MATERIAL PLATING terminal 1 copper alloy gold flash terminal 2 copper alloy gold flash terminal 3 copper alloy gold flash terminal 4 copper alloy gold flash terminal 5 copper alloy gold flash terminal 10 copper alloy gold flash terminal 11 copper alloy gold flash plastic PA10T Recommended PCB Layout Top View Model No. Ø2.5 SPECIAL MATING PLUG SJ2-25934A1-SMT SJ2-25934B1-SMT SJ2-25934C1-SMT SJ2-25934D1-SMT SJ2-25934D-SMT 1 sleeve sleeve sleeve sleeve sleeve 2 tip tip tip tip tip Schematic PIN 3 ring 1 ring 1 ring 1 ring 1 ring 1 4 ring 2 ring 2 ring 2 ring 2 ring 2 5 sleeve sleeve sleeve sleeve NP 10 NP tip switch NP tip switch tip switch 11 NP NP ring 1 switch ring 1 switch ring 1 switch cuidevices.com Additional Resources: Product Page CUI DEVICES | SERIES: SJ2-2593X-SMT | DESCRIPTION: AUDIO JACK date 08/18/2022 | page 3 of 4 SOLDERABILITY parameter conditions/description reel storage at relative humidity
SJ2-25934B1-SMT-TR 价格&库存
很抱歉,暂时无法提供与“SJ2-25934B1-SMT-TR”相匹配的价格&库存,您可以联系我们找货
SJ2-25934B1-SMT-TR
  • 157+5.48932
  • 542+5.15077
库存:640
SJ2-25934B1-SMT-TR
    • 109+7.13344109+0.91530
    • 550+6.16470550+0.79100
    库存:640
    SJ2-25934B1-SMT-TR
      • 109+6.56299
      • 550+5.66058
      库存:640
