SJ2-2523D-SMT-TR
SJ2-2523D-SMT-TR
    CUIDEVICES
    AUDIOJACK,2.5MM,RT,3CONDUC
SJ2-2523D-SMT-TR 数据手册
Additional Resources: Product Page date 08/18/2022 page 1 of 4 SERIES: SJ2-252X-SMT | DESCRIPTION: AUDIO JACK FEATURES • multiple switch configurations • low profile design • reflow solder compatible • surface mount PART NUMBER KEY SJ2 - 252 X X - SMT - TR Base Number Notes: # Conductors: 31 = 3 4=4 Switch Options: A = no switch B* = tip switch C* = ring switch D* = tip & ring switch Package Style: SMT = surface mount Packaging: TR = Tape & Reel 1. 3 conductor option only available with tip & ring switch *Discontinued models SJ2-2524D-SMT-TR, SJ2-2524B-SMT-TR, SJ2-2524C-SMT-TR & SJ2-2523D-SMT-TR SPECIFICATIONS parameter conditions/description min rated input voltage typ 12 rated input current contact resistance2 between terminal and mating plug between terminal in a closed circuit insulation resistance at 500 Vdc voltage withstand for 1 minute -25 life at a rate of 24 cycles/minute flammability rating UL94V-0 RoHS yes Vdc A 50 30 mΩ mΩ 500 Vac 3 kg MΩ 0.3 operating temperature 85 5,000 2. When measured at a current of less than 100 mA/1 kHz 3. All specifications measured at 10~35°C, humidity at 45~85%, under standard atmospheric pressure, unless otherwise noted. cuidevices.com units 1 100 insertion/withdrawal force Note: max °C cycles Additional Resources: Product Page CUI DEVICES | SERIES: SJ2-252X-SMT | DESCRIPTION: AUDIO JACK date 08/18/2022 | page 2 of 4 MECHANICAL DRAWING units: mm tolerance: X.X ±0.2 mm X.XX ±0.10 mm X.XXX ±0.050 mm PCB: ±0.05 mm MATERIAL PLATING terminal 1 copper alloy silver terminal 2 copper alloy silver terminal 3 copper alloy silver terminal 4 copper alloy silver terminal 10 brass silver terminal 11 brass silver plastic PA10T Recommended PCB Layout Top View 1 4 3 2 Model No. SJ2-2523D-SMT SJ2-2524A-SMT 4 11 Ø2.5 MATING PLUG 3 11 10 2 Schematic SJ2-2524B-SMT SJ2-2524C-SMT SJ2-2524D-SMT 1 4 1 4 1 4 1 4 3 3 2 10 2 3 11 3 11 10 2 2 PIN 1 NP sleeve sleeve sleeve sleeve 2 tip tip tip tip tip 3 ring 1 ring 1 ring 1 ring 1 ring 1 4 ring 2 ring 2 ring 2 ring 2 ring 2 10 tip switch NP tip switch NP tip switch 11 ring 1 switch NP NP ring 1 switch ring 1 switch cuidevices.com Additional Resources: Product Page CUI DEVICES | SERIES: SJ2-252X-SMT | DESCRIPTION: AUDIO JACK date 08/18/2022 | page 3 of 4 SOLDERABILITY parameter conditions/description reel storage at relative humidity
SJ2-2523D-SMT-TR 价格&库存
很抱歉,暂时无法提供与“SJ2-2523D-SMT-TR”相匹配的价格&库存,您可以联系我们找货
