SJ1-3555NG-BE
SJ1-3555NG-BE
    CUIDEVICES
    CONN JACK STEREO 3.5MM R/A
SJ1-3555NG-BE 数据手册
Additional Resources: Product Page | 3D Model | PCB Footprint date 10/04/2022 page 1 of 4 SERIES: SJ1-355XNG | DESCRIPTION: AUDIO JACK FEATURES • low profile design • switch options include: – no switch – tip switch – tip and ring switch PART NUMBER KEY SJ1 - 355 X NG - X Base Number Notes: Switch Options: 3 = no switch 4 = tip switch 5 = tip and ring switch Color Options: “blank” = black BE1 = blue 1. Tip and ring switch model only SPECIFICATIONS parameter conditions/description min rated input voltage typ max 12 rated input current contact resistance between terminal and mating plug between terminal in a closed circuit insulation resistance at 500 Vdc voltage withstand for 1 minute Vdc 1 A 50 30 mΩ mΩ 500 Vac kg 100 MΩ insertion/withdrawal force 0.3 3 operating temperature -25 85 life 5,000 flammability rating UL94V-0 RoHS yes cuidevices.com units °C cycles Additional Resources: Product Page | 3D Model | PCB Footprint CUI DEVICES | SERIES: SJ1-355XNG | DESCRIPTION: AUDIO JACK date 10/04/2022 | page 2 of 4 MECHANICAL DRAWING units: mm tolerance: X.X ±0.3 mm X.XX ±0.25 mm X.XXX ±0.20 mm PCB: ±0.05 mm unless otherwise specified DESCRIPTION MATERIAL PLATING/COLOR terminal 1 C2680 tin over nickel terminal 2 C5191 tin over nickel terminal 3 C5191 tin over nickel terminal 4 C2680 tin over nickel terminal 5 C2680 tin over nickel housing PBT (UL94V-0) black cover PBT (UL94V-0) black Recommended PCB Layout Top View 1 3 2 14 Ø3.5 MATING PLUG Model No. SJ1-3553NG SJ1-3554NG SJ1-3555NG 1 3 1 3 2 4 2 1 3 5 4 2 Schematic PIN 1 sleeve sleeve sleeve 2 tip tip tip 3 ring ring ring 4 NP tip switch tip switch 5 NP NP ring switch cuidevices.com Additional Resources: Product Page | 3D Model | PCB Footprint CUI DEVICES | SERIES: SJ1-355XNG | DESCRIPTION: AUDIO JACK date 10/04/2022 | page 3 of 4 SOLDERABILITY parameter conditions/description min typ max units wave soldering for max 5 seconds 255 260 265 °C Pin Temperature Component Temperature A. Preheating B. Soldering C. Cooling cuidevices.com Additional Resources: Product Page | 3D Model | PCB Footprint CUI DEVICES | SERIES: SJ1-355XNG | DESCRIPTION: AUDIO JACK date 10/04/2022 | page 4 of 4 REVISION HISTORY rev. description date 1.0 initial release 02/07/2006 1.01 new template applied 02/15/2012 1.02 updated datasheet 04/18/2017 1.03 brand update 10/10/2019 1.04 discontinued models SJ1-3555NG-GR & SJ1-3555NG-PI; logo, datasheet style update 08/18/2022 1.05 product reengineered for improved manufacturability and production yield, see PCN for details 10/04/2022 The revision history provided is for informational purposes only and is believed to be accurate. CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website. CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use. CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness. cuidevices.com
SJ1-3555NG-BE 价格&库存
很抱歉,暂时无法提供与“SJ1-3555NG-BE”相匹配的价格&库存,您可以联系我们找货
SJ1-3555NG-BE
  • 1+10.160301+1.27412
  • 10+8.6643310+1.08653
  • 25+8.1197725+1.01824
  • 50+7.7309450+0.96948
  • 100+7.36034100+0.92300
  • 300+6.81097300+0.85411
  • 500+6.56970500+0.82386
  • 1000+6.255951000+0.78451
  • 2500+5.864352500+0.73540
库存:1894
SJ1-3555NG-BE
  • 179+4.87268
  • 561+4.61877
  • 2243+4.43740
  • 5606+4.18349
  • 16817+4.00213
库存:19500
