PJRAS2X2S01AUX
PJRAS2X2S01AUX
    SWITCHCRAFT
    3.20mm ID, 9.00mm OD (RCA) Phono (RCA) Jack Mono Connector Solder
PJRAS2X2S01AUX 数据手册
PART NUMBER PJRAS2X2S01X PJRAS2X2S01AUX PJRAS2X2S01AUALLX INSERT COLOR INSERT COLOR A B C D WHITE WHITE RED RED WHITE WHITE RED RED WHITE WHITE RED RED SHELL AND SLEEVE TERMINAL FINISH NICKEL PLATED GOLD PLATED GOLD PLATED 1.063 [27,0] FRONT PLATE TIP TERMINAL FINISH TIN PLATED TIN PLATED GOLD PLATED T2 NICKEL PLATED T1 NICKEL PLATED S T1 T1 T2 S 0.345 [8,75] TYP (2) JACKS R0.008 [0,2] TYP (8) 0.295 [7,5] TYP (2) 0.118 [3,0] SCHEMATIC GOLD PLATED 0.059 [1,5] 0.094 HOUSING [2,4] 0.130 PLATE [3,3] 0.551 [14,0] FRONT PLATE FINISH 1.102 [28,0] 0.051 [1,3] TYP (4) T2 0.492 [12,5] S 0.207 [5,25] 0.539 [13,7] 0.059 [1,5] 0.551 [14,0] 0.323 [8,2] 0.969 [24,6] INSERT (B) P.C. BOARD LAYOUT INSERT (A) COMPONENT SIDE TIP (T2) TERMINALS 0.327 [8,3] 0.413 [10,5] HOUSING 0.551 [14,0] 1.122 [28,5] 0.532 [13,5] 0.256 [6,5] TIP (T1) TERMINALS SHELL INSULATOR 0.158 [4,0] 0.148 [3,75] TYP (2) INSERT (C) NOTES: INSERT (D) SLEEVE (S) TERMINALS 0.197 [5,0] 0.969 [24,6] 0.039 [1,0] TYP (4) 0.148 [3,75] TYP (2) 0.345 [8,75] 0.148 [3,75] TYP (2) 0.492 [12,5] 1. ALL DIMENSIONS ARE REFERENCE. CUSTOMER DRAWING 2. MATERIALS: B HOUSING: ABS OR PBT, UL-94HB, BLACK B COLOR INSERT: POM OR PBT, UL-94HB B INSULATOR: POM OR PBT, UL-94HB UNLESS OTHERWISE SPECIFIED 1. ALL DIMENSIONS IN INCHES -TWO PLACE DECIMALS 0.01 -THREE PLACE DECIMALS 0.005 -ANGLES 1 -ALL DIA. CONCENTRIC WITHIN 0.005 T.I.R. SHELL & SLEEVE TERMINALS: COPPER ALLOY, SEE TABLE TIP TERMINALS: COPPER ALLOY, SEE TABLE FRONT PLATE: COPPER ALLOY, SEE TABLE 3. THIS PART IS RoHS COMPLIANT THIS DRAWING DESCRIBES A DESIGN CONSIDERED PROPRIETARY IN NATURE, DEVELOPED AND MANUFACTURED BY SWITCHCRAFT INC. AND IS RELEASED ON A CONFIDENTIAL BASIS FOR IDENTIFICATION PURPOSES ONLY. STAR SYMBOL DENOTES CRITICAL DIMENSION B 27929 08-17-17 PC TJK 2. FEATURES ON THE SAME CENTERLINE MUST BE ALIGNED WITHIN 0.002 A 25181 1-13-06 JL TJK 3. REMOVE ALL BURRS REV ECO NUMBER DATE BY APVD REVISIONS SIZE WIDTH FINISH SCALE DATE DRAWN BY CHKD 13-Jan-06 JL TJK 1-13-06 2:1 APVD TJK 1-13-06 PHONO JACK, RIGHT ANGLE, 4 POS. SCREW MOUNT, SHIELDED, RoHS B TEMPER SPEC No. FIRST USED ON DO NOT SCALE DRAWING LBS/M MATERIAL SPEC No. NAME Pro/Engineer CAD File MULT SHEET 1 OF 1 PART No. PJRAS2X2S__X SERIES REV B
PJRAS2X2S01AUX 价格&库存
很抱歉,暂时无法提供与“PJRAS2X2S01AUX”相匹配的价格&库存,您可以联系我们找货
