SJ2-25774A-SMT-TR
SJ2-25774A-SMT-TR
    CUIDEVICES
    AUDIOJACK,2.5MM,RT,4CONDUC
SJ2-25774A-SMT-TR 数据手册
Additional Resources: Product Page | 3D Model | PCB Footprint date 10/04/2019 page 1 of 4 SERIES: SJ2-2577X-SMT │ DESCRIPTION: AUDIO JACK FEATURES • • • • mid mount SMT for low profile designs right angle reflow solder compatible suitable for medical applications PART NUMBER KEY SJ2-2577 X X - SMT-TR Base Number Note: # Conductors: 31 = 3 4=4 Switch Options: A = no switch B = tip switch Package Style: SMT = surface mount Packaging: TR = Tape & Reel 1. 3 conductor option only available with tip switch SPECIFICATIONS parameter conditions/description min rated input voltage typ 12 rated input current contact resistance2 between terminal and mating plug between terminal in a closed circuit insulation resistance at 500 Vdc voltage withstand for 1 minute 1 A 50 30 mΩ mΩ MΩ 0.3 operating temperature -25 life at a rate of 24 cycles/minute flammability rating UL94V-0 RoHS yes 500 Vac 3 kg 85 5,000 2. When measured at a current of less than 100 mA/1 kHz 3. All specifications measured at 10~35°C, humidity at 45~85%, under standard atmospheric pressure, unless otherwise noted. cuidevices.com units Vdc 100 insertion/withdrawal force Note: max °C cycles Additional Resources: Product Page | 3D Model | PCB Footprint CUI Devices │ SERIES: SJ2-2577X-SMT │ DESCRIPTION: AUDIO JACK date 10/04/2019│ page 2 of 4 MECHANICAL DRAWING units: mm tolerance: X.X ±0.2 mm X.XX ±0.10 mm X.XXX ±0.050 mm PCB: ±0.05 mm MATERIAL PLATING terminal 1 copper alloy silver terminal 2 copper alloy silver terminal 3 copper alloy silver terminal 4 copper alloy silver terminal 10 brass silver plastic PA10T Recommended PCB Layout Top View 1 4 3 2 Model No. SJ2-25773B-SMT SJ2-25774A-SMT 4 11 Ø2.5 MATING PLUG 3 Schematic 10 2 SJ2-25774B-SMT 1 4 1 4 3 3 2 10 2 PIN 1 NP sleeve sleeve 2 tip tip tip 3 ring 1 ring 1 ring 1 4 ring 2 ring 2 ring 2 10 tip switch NP tip switch cuidevices.com Additional Resources: Product Page | 3D Model | PCB Footprint CUI Devices │ SERIES: SJ2-2577X-SMT │ DESCRIPTION: AUDIO JACK date 10/04/2019│ page 3 of 4 SOLDERABILITY parameter conditions/description reel storage at relative humidity
SJ2-25774A-SMT-TR 价格&库存
很抱歉,暂时无法提供与“SJ2-25774A-SMT-TR”相匹配的价格&库存,您可以联系我们找货
SJ2-25774A-SMT-TR
  • 1+9.190191+1.14606
  • 10+7.8067610+0.97354
  • 25+7.3203225+0.91288
  • 50+6.9705950+0.86927
  • 100+6.63700100+0.82767
  • 250+6.22081250+0.77577
  • 500+5.92350500+0.73869
库存:2527
SJ2-25774A-SMT-TR
  • 1200+5.568601200+0.69443
  • 2400+5.302802400+0.66129
  • 3600+5.153323600+0.64265
  • 6000+4.971016000+0.61991
  • 8400+4.854468400+0.60538
  • 12000+4.7339312000+0.59035
库存:2527
