SJ2-25404A-SMT-TR
SJ2-25404A-SMT-TR
    CUIDEVICES
    AUDIOJACK,2.5MM,RT,4CONDUC
SJ2-25404A-SMT-TR 数据手册
Additional Resources: Product Page date 08/18/2022 page 1 of 4 SERIES: SJ2-2540X-SMT | DESCRIPTION: AUDIO JACK FEATURES • gold flash terminal plating • mulitple switch configurations • low profile design • reflow solder profile PART NUMBER KEY SJ2 - 2540 X X - SMT - TR Base Number Notes: # Conductors: 4=4 Switch Options: A* = no switch B = tip switch C* = ring switch D = tip & ring switch Package Style: SMT = surface mount Packaging: TR = Tape & Reel *Discontinued models SJ2-25404A-SMT-TR & SJ2-25404C-SMT-TR SPECIFICATIONS parameter conditions/description min rated input voltage typ max 12 rated input current contact resistance1 between terminal and mating plug between terminal in a closed circuit insulation resistance at 500 Vdc voltage withstand for 1 minute Vdc 1 A 50 30 mΩ mΩ 500 Vac kg 100 MΩ insertion/withdrawal force 0.3 3 operating temperature -25 85 life at a rate of 24 cycles/minute flammability rating UL94V-0 RoHS yes Note: 5,000 1. When measured at a current of less than 100 mA/1 kHz 2. All specifications measured at 10~35°C, humidity at 45~85%, under standard atmospheric pressure, unless otherwise noted. cuidevices.com units °C cycles Additional Resources: Product Page CUI DEVICES | SERIES: SJ2-2540X-SMT | DESCRIPTION: AUDIO JACK date 08/18/2022 | page 2 of 4 MECHANICAL DRAWING units: mm tolerance: X.X ±0.2 mm X.XX ±0.10 mm X.XXX ±0.050 mm PCB: ±0.05 mm MATERIAL PLATING terminal 1 copper alloy gold flash terminal 2 copper alloy gold flash terminal 3 copper alloy gold flash terminal 4 copper alloy gold flash terminal 10 copper alloy gold flash terminal 11 copper alloy gold flash plastic PA10T Recommended PCB Layout Top View 1 4 3 2 11 Ø2.5 MATING PLUG Model No. SJ2-25404A-SMT Schematic SJ2-25404B-SMT SJ2-25404C-SMT SJ2-25404D-SMT 1 4 1 4 1 4 1 4 3 3 2 10 2 3 11 3 11 10 2 2 PIN 1 sleeve sleeve sleeve sleeve 2 tip tip tip tip 3 ring 1 ring 1 ring 1 ring 1 4 ring 2 ring 2 ring 2 ring 2 10 NP tip switch NP tip switch 11 NP NP ring 1 switch ring 1 switch cuidevices.com Additional Resources: Product Page CUI DEVICES | SERIES: SJ2-2540X-SMT | DESCRIPTION: AUDIO JACK date 08/18/2022 | page 3 of 4 SOLDERABILITY parameter conditions/description reel storage at relative humidity
SJ2-25404A-SMT-TR 价格&库存
很抱歉,暂时无法提供与“SJ2-25404A-SMT-TR”相匹配的价格&库存,您可以联系我们找货
SJ2-25404A-SMT-TR
  • 1+10.655661+1.33758
  • 10+9.0388310+1.13462
  • 25+8.4746825+1.06381
  • 50+8.0676850+1.01272
  • 100+7.68158100+0.96425
  • 250+7.20057250+0.90387
库存:474
