PART
NUMBER
INSERT
COLOR
SHELL AND SLEEVE
TERMINAL FINISH
PJRAN1X1U01X
BLACK
NICKEL PLATED
PJRAN1X1U01AUX
BLACK
GOLD PLATED
PJRAN1X1U02X
WHITE
NICKEL PLATED
PJRAN1X1U02AUX
WHITE
GOLD PLATED
PJRAN1X1U03X
RED
NICKEL PLATED
PJRAN1X1U03AUX
RED
GOLD PLATED
PJRAN1X1U04X
YELLOW
NICKEL PLATED
PJRAN1X1U04AUX
YELLOW
GOLD PLATED
PJRAN1X1U07X
ORANGE
NICKEL PLATED
NOTES:
1. ALL DIMENSIONS ARE REFERENCE.
2. MATERIALS:
B
HOUSING: ABS OR PBT, UL-94HB, BLACK OR SAME COLOR AS INSERT.
B
COLOR INSERT: POM OR PBT, UL-94HB
SHELL & SLEEVE TERMINAL: COPPER ALLOY, NICKEL OR GOLD PLATED
TIP & SHUNT TERMINALS: COPPER ALLOY, TIN PLATED
2
3
1
SCHEMATIC
3. THIS PART IS RoHS COMPLIANT
0.394
[10,0]
0.158
[4,0]
0.768
[19,5]
INSERT
0.133
[3,4]
HOUSING
0.374
[9,5]
SHELL
0.197
[5,0]
0.059
[1,5]
TIP (2)
0.327
[8,3]
0.649
[16,5]
0.315
[8,0]
0.158
[4,0]
SHUNT (3)
0.039 X 0.098
[1.0] X [2.5]
TYP (2)
0.295
[7,5]
0.082
[2,1]
0.532
[13,5]
SLEEVE (1)
0.295
[7,5]
0.146
[3,7]
CUSTOMER DRAWING
0.158
[4,0]
THIS DRAWING DESCRIBES A DESIGN CONSIDERED PROPRIETARY IN NATURE, DEVELOPED AND MANUFACTURED
BY SWITCHCRAFT INC. AND IS RELEASED ON A CONFIDENTIAL BASIS FOR IDENTIFICATION PURPOSES ONLY.
STAR SYMBOL DENOTES CRITICAL DIMENSION
UNLESS OTHERWISE SPECIFIED
1. ALL DIMENSIONS IN INCHES
-TWO PLACE DECIMALS
0.01
-THREE PLACE DECIMALS
0.005
-ANGLES
1
-ALL DIA. CONCENTRIC WITHIN 0.005 T.I.R.
0.098 x 0.051
[2.5] x [1.3]
0.079
[2,0]
P.C. BOARD LAYOUT
COMPONENT SIDE
0.158
[4,0]
B
27929
08-17-17
PC
TJK
2. FEATURES ON THE SAME CENTERLINE
MUST BE ALIGNED WITHIN 0.002
A
25181
1-13-06
JL
TJK
3. REMOVE ALL BURRS
REV
ECO NUMBER
DATE
BY
APVD
REVISIONS
SIZE
MULT
FINISH
SCALE
DATE DRAWN
BY
CHKD
13-Jan-06
JL
TJK
1-13-06
3:1
APVD
TJK
1-13-06
PHONO JACK - RIGHT ANGLE
1 POS, PC MOUNT, UNSHIELDED, RoHS
B
TEMPER
SPEC No.
FIRST USED ON
DO NOT SCALE DRAWING
LBS/M
MATERIAL
SPEC No.
NAME
Pro/Engineer CAD File
WIDTH
SHEET
1
OF
1
PART No.
PJRAN1X1U__X SERIES
REV
B
很抱歉,暂时无法提供与“PJRAN1X1U03AUX”相匹配的价格&库存,您可以联系我们找货
