NPB
560B
Sw
i
t
c
h
c
r
a
f
t
EH Series
Audio/Video/Data
1. Choose any combination
of EH Series connectors.
The EH Series by Switchcraft® is a complete line of audio, video, and data
connectors built into standard panel-mount XLR housings. Custom
combinations of EH Series connectors can be quickly loaded into any of our
Q-G® Series panels. Once mounted, connecting your equipment to the
back of an EH Series connector is fast and easy. Most connectors are
feedthru, which means standard cabling is simply plugged into the back
of your gear, then plugged into the back of the EH Series connector. For
those EH Series connectors that are not feedthru, solder lugs are clearly
marked for simple, secure solder connections. All EH Series connectors
are available individually bagged with mounting screws.
2. Choose a blank Q-G®
Series panel.
Q-G® Series panels come standard as 1RU (1x16), 1.5RU (1x16), or 2RU
(2x16). 1RU and 1.5RU versions allow for any combination of up to 16 EH
Series connectors to be loaded into the panel. The 2RU version can
accommodate up to 32 EH Series connectors. Every Q-G® Series panel
includes quick change designation strips for easy connector identification.
3. Populate EH Series
connectors into Q-G®
Series panel to create
custom I/O solution for
all of your audio, video,
and data connections.
Switchcraft's EH Series is the fastest and most versatile way to create a
custom panel or wall plate perfectly suited to meet the needs of any studio,
broadcast facility, or systems integrator. Customize your studio, make it
easy to access your I/O's, and increase the lifespan of expensive pieces
of equipment using EH Series connectors and Q-G® Series Panels from
Switchcraft®.
-QGPK1B440
Switchcraft
www.switchcraft.com®
5555 N. Elston Avenue/Chicago, IL 60630
Phone: 773-792-2700 Fax: 773-792-2129
EH Series
Switchcraft®
2 NPB 560B Audio/Video/Data
E3MSCB
E3FSC
E4MSC
E4FSC
E5MSCB
E5FSC
E112BL
EH35MMMSC
EHUSBBAB
EHUSBAB
EHFWX2B
EHFW800X2
EH6MD2
EHSVHS2B
EHRCA2
EHDB9MF
EHDB9FFB
EHHD15MF
EHHD15FFB
EHFFB
EHBNC2B
EHLC2
EHLC2M
EHSC2
EHSC2M
EHST2
EHST2MB
EHTL2
ECPPKG
Switchcraft
ECP2PKG
ECP4PKG
ECP8PKG
EH Series
Switchcraft®
NPB 560B 3
Audio/Video/Data
Connector Options
1
EH Series
Termination Housing Connector
3.5MM (1/8") Mono
3.5MM (1/8") Stereo
SVHS (S-Video)
PS/2
Firewire 400 (IEEE1394) Straight-Wired
Firewire 400 (IEEE1394) Cross-Wired
Firewire 800 (IEEE1394B) Straight-Wired
Firewire 800 (IEEE1394B) Cross-Wired
RCA
BNC
BNC (Recessed Front)
BNC
BNC to RCA
RCA to BNC
USB A to B
USB B to A
9-Pin DSUB Male to Male
9-Pin DSUB Male to Female
9-Pin DSUB Female to Female
15-Pin HD DSUB Male to Male
15-Pin HD DSUB Male to Female
15-Pin HD DSUB Female to Female
F to F (Coaxial)
LC Fiber Optic (singlemode)
LC Fiber Optic (multimode)
SC Fiber Optic (singlemode)
SC Fiber Optic (multimode)
ST Fiber Optic (singlemode)
ST Fiber Optic (multimode)
TOSLINK
E Series
(XLR)
E
2
Solder
Solder
Feedthru
Feedthru
Feedthru
Feedthru
Feedthru
Feedthru
Feedthru
Feedthru
Feedthru
Solder
Feedthru
Feedthru
Feedthru
Feedthru
Feedthru
Feedthru
Feedthru
Feedthru
Feedthru
Feedthru
Feedthru
Feedthru
Feedthru
Feedthru
Feedthru
Feedthru
Feedthru
Feedthru
EH
EH
EH
EH
EH
EH
EH
EH
EH
EH
EH
EH
EH
EH
EH
EH
EH
EH
EH
EH
EH
EH
EH
EH
EH
EH
EH
EH
EH
EH
35MMMSC
35MMSSC
SVHS2
6MD2
FW2
FWX2
FW8002
FW800X2
RCA2
BNC2
BNC2R
BNCSC
BNCRCA
RCABNC
USBAB
USBBA
DB9MM
DB9MF
DB9FF
HD15MM
HD15MF
HD15FF
FF
LC2
LC2M
SC2
SC2M
ST2
ST2M
TL2
Pins Gender
Fas-Disconnect
Option
Termination Style
3,4,5
D=Fas-Disconnect
Blank=Standard
Locking
ST=Straight PC Terminals
RA=Right Angle PC Terminals
SC=Solder Cups
Blank=Conical Springs (3-Pin)
M, F
Connector Type
1/4" Mono Locking Jack
1/4" Stereo Locking Jack
Part Number Part Number
Bagged with
(Nickel Finish) (Black Finish) Mounting Screws
E111L
E112BL
E111BL
E112BLB
PKG
PKG
Finish
3
B = Black
Blank = Nickel
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
(Black Only)
(Black Only)
(Black Only)
(Black Only)
B
B
(Black Only)
Mounting Hole
Options
4
Bagged with
Mounting Screws
PKG
PKG
PKG
PKG
PKG
PKG
PKG
PKG
PKG
PKG
PKG
PKG
PKG
PKG
PKG
PKG
PKG
PKG
PKG
PKG
PKG
PKG
PKG
PKG
PKG
PKG
PKG
PKG
PKG
PKG
Bagged with
Mounting Screws
M3=M3x0.5 Thread
B=Black
440=#4-40 Thread
Blank=Nickel Blank=Counter-Sunk
Hole
PKG
Blank Hole Covers
Part Number
1 Space
2 Space
4 Space
8 Space
ECPPKG
ECP2PKG
ECP4PKG
ECP8PKG
*Sample EH Series Part Number: EHBNC2BPKG (BNC Feedthru, Black Housing, Bagged with 4-40 Mounting Screws)
*Sample E Series Part Number: E3FSCPKG (3-Pin XLR Female, Solder Cups, Bagged with 4-40 Mounting Screws)
*Male to female 9-Pin and 15-Pin DSUBS are user reversible to create female to male connectors.
*All Blank Hole Covers come bagged with 4-40 mounting screws.
*All EH Series Fiber Optic Connectors come with dust caps.
Switchcraft
EH Series
Switchcraft®
4 NPB 560B Audio/Video/Data
Q-G® Panel Options
-QGPK1B440
Empty Q-G® Rack Panels
Rack Height
Number of Knockouts
Tapped 4-40 Holes
QGPK1B
QGPK1B440
QGPK2B
QGPK2B440
QGPK3B
QGPK3B440
1RU
1RU
1.5RU
1.5RU
2RU
2RU
1 X 16
1 x 16
1 X 16
1 X 16
2 X 16
2 X 16
NO
YES
NO
YES
NO
YES
-QGPK332MFB
Pre-Loaded XLR Panels
QGPK116FB
QGPK116MB
QGPK18M8FB
QGPK332MFB
Switchcraft
Height
1RU
1RU
1RU
2RU
Description
16 Female
16 Male
8 Male, 8 Female
16 Female, 16 Male
很抱歉,暂时无法提供与“EH35MMSSCBPKG”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+235.704241+30.49195
- 10+200.3384610+25.91684
- 25+187.7952725+24.29419
- 50+178.8353250+23.13508
- 100+170.30505100+22.03156
- 250+159.65289250+20.65354
- 500+152.04388500+19.66920
