RCP-015
RCP-015
    CUIDEVICES
    CONN RCA PLUG MONO 2COND
RCP-015 数据手册
Additional Resources: Product Page date 07/24/2015 page 1 of 3 SERIES: RCP-01 │ DESCRIPTION: RCA PLUG ED FEATURES N U • modular RCA plug connector • available in multiple colors TI PART NUMBER KEY RCP-01 X O N Base Number Color Options 1 = black 2 = red 3 = white 4 = yellow 5 = blue 6 = green SPECIFICATIONS parameter min typ rated input current contact resistance insulation resistance at 500 Vdc voltage withstand for 1 minute 2011/65/EU D UL94HB RoHS Vdc A 30 mΩ MΩ 500 -40 life units 5 100 operating temperature flammability max 12 IS C rated input voltage conditions/description 40 5,000 Vac °C cycles SOLDERABILITY parameter conditions/description hand soldering for 3~5 seconds min typ 340 cui.com max units °C Additional Resources: Product Page CUI Inc │ SERIES: RCP-01 │ DESCRIPTION: RCA PLUG date 07/24/2015│ page 2 of 3 MECHANICAL DRAWING units: mm[inches] tolerance: ±0.3 mm unless otherwise specified PLATING brass nickel ED earth terminal MATERIAL tip terminal brass nickel barrel brass nickel ABS color ABS color cover U barrel housing 36.5 1.437 N 14.3 0.563 18.3 0.720 8.3 0.327 12.0 0.472 TI 3.0 0.118 N 9.0 0.354 O 6.4 0.252 D IS C 3.2 0.126 cui.com 19.6 0.772 M9 Additional Resources: Product Page CUI Inc │ SERIES: RCP-01 │ DESCRIPTION: RCA PLUG date 07/24/2015│ page 3 of 3 REVISION HISTORY description 1.0 initial release 1.01 applied new spec template date 05/16/2006 ED rev. 07/24/2015 D IS C O N TI N U The revision history provided is for informational purposes only and is believed to be accurate. Headquarters 20050 SW 112th Ave. Tualatin, OR 97062 800.275.4899 Fax 503.612.2383 cui.com techsupport@cui.com CUI offers a one (1) year limited warranty. Complete warranty information is listed on our website. CUI reserves the right to make changes to the product at any time without notice. Information provided by CUI is believed to be accurate and reliable. However, no responsibility is assumed by CUI for its use, nor for any infringements of patents or other rights of third parties which may result from its use. CUI products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness.
RCP-015 价格&库存
很抱歉,暂时无法提供与“RCP-015”相匹配的价格&库存,您可以联系我们找货
RCP-015
    • 173+5.05404
    • 538+4.78804
    • 2151+4.61877
    库存:2500
