SJ2-25103B-SMT-TR
SJ2-25103B-SMT-TR
    CUIDEVICES
    AUDIOJACK,2.5MM,RT,3CONDUC
SJ2-25103B-SMT-TR 数据手册
Additional Resources: Product Page | 3D Model | PCB Footprint date 08/18/2022 page 1 of 4 SERIES: SJ2-2510X-SMT | DESCRIPTION: AUDIO JACK FEATURES • right angle • low profile design • reflow solder compatible • surface mount PART NUMBER KEY SJ2 - 2510 X X - SMT - TR Base Number Notes: # Conductors: 2=2 3=3 Switch Options: A* = no switch B*= tip switch Package Style: SMT = surface mount Packaging: TR = Tape & Reel *Discontinued models SJ2-25103B-SMT-TR & SJ2-25102A-SMT-TR SPECIFICATIONS parameter conditions/description min rated input voltage typ max 12 rated input current contact resistance1 between terminal and mating plug between terminal in a closed circuit insulation resistance at 500 Vdc voltage withstand for 1 minute Vdc 1 A 50 30 mΩ mΩ 500 Vac kg 100 MΩ insertion/withdrawal force 0.3 3 operating temperature -25 85 life at a rate of 24 cycles/minute flammability rating UL94V-0 RoHS yes Note: 5,000 1. When measured at a current of less than 100 mA/1 kHz 2. All specifications measured at 10~35°C, humidity at 45~85%, under standard atmospheric pressure, unless otherwise noted. cuidevices.com units °C cycles Additional Resources: Product Page | 3D Model | PCB Footprint CUI DEVICES | SERIES: SJ2-2510X-SMT | DESCRIPTION: AUDIO JACK date 08/18/2022 | page 2 of 4 MECHANICAL DRAWING units: mm tolerance: X.X ±0.2 mm X.XX ±0.10 mm X.XXX ±0.050 mm PCB: ±0.05 mm MATERIAL PLATING terminal 1 copper alloy silver terminal 2 copper alloy silver terminal 3 copper alloy silver terminal 10 copper alloy silver plastic PA10T Recommended PCB Layout Top View 1 3 2 11 Ø2.5 MATING PLUG Model No. SJ2-25102A-SMT SJ2-25102B-SMT 1 1 2 10 2 Schematic SJ2-25103A-SMT SJ2-25103B-SMT 1 3 1 3 2 10 2 PIN 1 sleeve sleeve sleeve sleeve 2 tip tip tip tip 3 NP NP ring ring 10 NP tip switch NP tip switch cuidevices.com Additional Resources: Product Page | 3D Model | PCB Footprint CUI DEVICES | SERIES: SJ2-2510X-SMT | DESCRIPTION: AUDIO JACK date 08/18/2022 | page 3 of 4 SOLDERABILITY parameter conditions/description reel storage at relative humidity
SJ2-25103B-SMT-TR 价格&库存
很抱歉,暂时无法提供与“SJ2-25103B-SMT-TR”相匹配的价格&库存,您可以联系我们找货
