SJ2-25515A-SMT-TR
SJ2-25515A-SMT-TR
    CUIDEVICES
    AUDIOJACK,2.5MM,RT,5CONDUC
SJ2-25515A-SMT-TR 数据手册
Additional Resources: Product Page date 10/07/2019 page 1 of 4 SERIES: SJ2-2551X-SMT │ DESCRIPTION: AUDIO JACK multiple switch configurations low profile design reflow solder compatible surface mount suitable for medical applications N U • • • • • ED FEATURES TI PART NUMBER KEY SJ2-2551 X X - SMT-TR Switch Options: A = no switch B = tip switch C = ring switch D = tip & ring switch N # Conductors: 5=5 O Base Number Package Style: SMT = surface mount Packaging: TR = Tape & Reel SPECIFICATIONS parameter min typ rated input current contact resistance1 between terminal and mating plug between terminal in a closed circuit insulation resistance at 500 Vdc voltage withstand for 1 minute -25 life at a rate of 24 cycles/minute flammability rating UL94V-0 RoHS yes D 1 A 50 30 mΩ mΩ MΩ 0.3 operating temperature 500 Vac 3 kg 85 5,000 1. When measured at a current of less than 100 mA/1 kHz 2. All specifications measured at 10~35°C, humidity at 45~85%, under standard atmospheric pressure, unless otherwise noted. cuidevices.com units Vdc 100 insertion/withdrawal force Note: max 12 IS C rated input voltage conditions/description °C cycles Additional Resources: Product Page CUI Devices │ SERIES: SJ2-2551X-SMT │ DESCRIPTION: AUDIO JACK date 10/07/2019│ page 2 of 4 MECHANICAL DRAWING PLATING terminal 1 brass gold flash terminal 2 copper alloy silver terminal 3 copper alloy silver terminal 4 copper alloy silver terminal 5 copper alloy silver terminal 10 brass silver terminal 11 brass silver plastic PA10T ED MATERIAL IS C O N TI N U units: mm tolerance: X.X ±0.2 mm X.XX ±0.10 mm X.XXX ±0.050 mm PCB: ±0.05 mm 5 4 3 2 Model No. SJ2-25515A-SMT Ø4.4 1 D 11 Ø2.5 MATING PLUG Recommended PCB Layout Top View Schematic SJ2-25515B-SMT 1 5 4 3 1 5 4 3 2 10 2 SJ2-25515C-SMT SJ2-25515D-SMT 1 5 4 3 11 1 5 4 3 11 10 2 2 PIN 1 outer ring outer ring outer ring outer ring 2 tip tip tip tip 3 ring 1 ring 1 ring 1 ring 1 4 ring 2 ring 2 ring 2 ring 2 5 sleeve sleeve sleeve sleeve 10 NP tip switch NP tip switch 11 NP NP ring 1 switch ring 1 switch cuidevices.com Additional Resources: Product Page CUI Devices │ SERIES: SJ2-2551X-SMT │ DESCRIPTION: AUDIO JACK date 10/07/2019│ page 3 of 4 SOLDERABILITY parameter conditions/description reel storage at relative humidity
SJ2-25515A-SMT-TR 价格&库存
很抱歉,暂时无法提供与“SJ2-25515A-SMT-TR”相匹配的价格&库存,您可以联系我们找货
SJ2-25515A-SMT-TR
