Additional Resources:
Product Page
date
08/18/2022
page 1 of 4
SERIES: SJ2-2540X-SMT | DESCRIPTION: AUDIO JACK
FEATURES
• gold flash terminal plating
• mulitple switch configurations
• low profile design
• reflow solder profile
PART NUMBER KEY
SJ2 - 2540 X X - SMT - TR
Base Number
Notes:
# Conductors:
4=4
Switch Options:
A* = no switch
B = tip switch
C* = ring switch
D = tip & ring switch
Package Style:
SMT = surface mount
Packaging:
TR = Tape & Reel
*Discontinued models SJ2-25404A-SMT-TR & SJ2-25404C-SMT-TR
SPECIFICATIONS
parameter
conditions/description
min
rated input voltage
typ
max
12
rated input current
contact resistance1
between terminal and mating plug
between terminal in a closed circuit
insulation resistance
at 500 Vdc
voltage withstand
for 1 minute
Vdc
1
A
50
30
mΩ
mΩ
500
Vac
kg
100
MΩ
insertion/withdrawal force
0.3
3
operating temperature
-25
85
life
at a rate of 24 cycles/minute
flammability rating
UL94V-0
RoHS
yes
Note:
5,000
1. When measured at a current of less than 100 mA/1 kHz
2. All specifications measured at 10~35°C, humidity at 45~85%, under standard atmospheric pressure, unless otherwise noted.
cuidevices.com
units
°C
cycles
Product Page
CUI DEVICES | SERIES: SJ2-2540X-SMT | DESCRIPTION: AUDIO JACK
date 08/18/2022 | page 2 of 4
MECHANICAL DRAWING
units: mm
tolerance:
X.X ±0.2 mm
X.XX ±0.10 mm
X.XXX ±0.050 mm
PCB: ±0.05 mm
MATERIAL
PLATING
terminal 1
copper alloy
gold flash
terminal 2
copper alloy
gold flash
terminal 3
copper alloy
gold flash
terminal 4
copper alloy
gold flash
terminal 10
copper alloy
gold flash
terminal 11
copper alloy
gold flash
plastic
PA10T
Recommended PCB Layout
Top View
1 4 3
2
11
Ø2.5 MATING PLUG
Model No.
SJ2-25404A-SMT
Schematic
SJ2-25404B-SMT
SJ2-25404C-SMT
SJ2-25404D-SMT
1
4
1
4
1
4
1
4
3
3
2
10
2
3
11
3
11
10
2
2
PIN
1
sleeve
sleeve
sleeve
sleeve
2
tip
tip
tip
tip
3
ring 1
ring 1
ring 1
ring 1
4
ring 2
ring 2
ring 2
ring 2
10
NP
tip switch
NP
tip switch
11
NP
NP
ring 1 switch
ring 1 switch
cuidevices.com
Product Page
date 08/18/2022 | page 3 of 4
SOLDERABILITY
parameter
reel storage
at relative humidity
很抱歉,暂时无法提供与“SJ2-254066A-SMT-TR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1000+7.287121000+0.93466
- 国内价格 香港价格
- 1+13.426491+1.72209
- 10+11.4386810+1.46714
- 25+10.7164125+1.37450
- 50+10.2058450+1.30901
- 100+9.71727100+1.24635
- 250+9.10869250+1.16829
- 500+8.67358500+1.11248
