Additional Resources:
Product Page
date
August18,2022115: 9AM
page 1 of 4
SERIES: SJ2-3582X-SMT | DESCRIPTION: AUDIO JACK
FEATURES
• 5 conductor
• right angle
• reflow solder compatible
• surface mount
PART NUMBER KEY
SJ2 - 3582 X X - SMT - TR
Base Number
Notes:
# Conductors:
5=5
Switch Options:
A = no switch
D* = tip & ring switch
Package Style:
SMT = surface mount
Packaging:
TR = Tape & Reel
*Discontinued model SJ2-35825D-SMT-TR
SPECIFICATIONS
parameter
conditions/description
min
rated input voltage
typ
max
12
rated input current
contact resistance1
between terminal and mating plug
between terminal in a closed circuit
insulation resistance
at 500 Vdc
voltage withstand
for 1 minute
Vdc
1
A
50
30
mΩ
mΩ
500
Vac
kg
100
MΩ
insertion/withdrawal force
0.3
3
operating temperature
-25
85
life
at a rate of 24 cycles/minute
flammability rating
UL94V-0
RoHS
yes
Note:
5,000
1. When measured at a current of less than 100 mA/1 kHz
2. All specifications measured at 10~35°C, humidity at 45~85%, under standard atmospheric pressure, unless otherwise noted.
cuidevices.com
units
°C
cycles
Product Page
date August 18, 2022 11:59 AM |
CUI DEVICES | SERIES: SJ2-3582X-SMT | DESCRIPTION: AUDIO JACK
page 2 of 4
MECHANICAL DRAWING
units: mm
tolerance:
X.X ±0.2 mm
X.XX ±0.10 mm
X.XXX ±0.050 mm
PCB: ±0.05 mm
MATERIAL
PLATING
terminal 1
copper alloy
silver
terminal 2
copper alloy
silver
terminal 3
copper alloy
silver
terminal 4
copper alloy
silver
terminal 5
copper alloy
silver
terminal 10
brass
silver
terminal 11
brass
silver
plastic
PA10T
Recommended PCB Layout
Top View
Model No.
SJ2-35825A-SMT
SJ2-35825D-SMT
1
outer ring
outer ring
2
tip
tip
Schematic
Ø3.5 MATING PLUG
PIN
3
ring 1
ring 1
4
ring 2
ring 2
5
sleeve
sleeve
10
NP
tip switch
11
NP
ring 1 switch
cuidevices.com
Product Page
page 3 of 4
SOLDERABILITY
parameter
reel storage
at relative humidity
很抱歉,暂时无法提供与“SJ2-35825D-SMT-TR”相匹配的价格&库存,您可以联系我们找货
