NOTES:
BPJ
1. 0.197 [5,0] MAX. PANEL THICKNESS
01
X
RoHS COMPLIANT
REAR MOUNT
3. THIS PRODUCT IS RoHS COMPLIANT.
PLATING:
AU = GOLD
BLANK = NICKEL
INSULATOR COLOR
01 = BLACK
02 = RED
03 = WHITE
04 = YELLOW
05 = BLUE
06 = GREEN
0.850 REF
[21,6]
0.134 REF
[3,4]
AU
BULKHEAD PHONO JACK
2. MATERIALS:
BODY - BRASS, NICKEL OR GOLD PLATED
TIP TERMINAL - BRASS, NICKEL PLATED
INSULATOR - ABS
NUT - BRASS, NICKEL OR GOLD PLATED
TOOTH WASHER - STEEL, NICKEL PLATED
BODY TERMINAL - BRASS, NICKEL PLATED
0.433 REF
[11,0]
R
0.610 REF
[15,5]
TIP TERMINAL
0.059 HOLE
[1,5]
0.551 REF
[14,0]
0.325 REF
[8,25]
0.197 REF
[5,0]
B
TOOTH WASHER
BODY TERMINAL
3/8-32 UNEF REF
HEX NUT
0.504 REF
[12,80]
STAR SYMBOL DENOTES CRITICAL DIMENSION
UNLESS OTHERWISE SPECIFIED
1. ALL DIMENSIONS IN INCHES
-TWO PLACE DECIMALS
0.01
-THREE PLACE DECIMALS
0.005
-ANGLES
1
-ALL DIA. CONCENTRIC WITHIN 0.005 T.I.R.
B
28483
03-03-22
PC
TJK
2. FEATURES ON THE SAME CENTERLINE
MUST BE ALIGNED WITHIN
0.002
A
26014
3-16-07
TJK
TJK
3. REMOVE ALL BURRS
REV
ECO NUMBER
DATE
BY
APVD
REVISIONS
DO NOT SCALE DRAWING
Pro/Engineer CAD File
0.506 REF
[12,85]
B
B
0.079 REF
[2,0]
0.167 REF
[4,25]
CUSTOMER DRAWING
THIS DRAWING DESCRIBES A DESIGN CONSIDERED PROPRIETARY IN NATURE, DEVELOPED AND MANUFACTURED
BY SWITCHCRAFT INC. AND IS RELEASED ON A CONFIDENTIAL BASIS FOR IDENTIFICATION PURPOSES ONLY.
SIZE
WIDTH
MULT
FINISH
FIRST USED ON
SCALE
DATE DRAWN
BY
CHKD
3-16-07
TJK
TJK
3-16-07
A
TEMPER
MATERIAL
SPEC No.
NAME
LBS/M
RCA PHONO JACK
REAR MOUNT, RoHS
SPEC No.
2:1
APVD
TJK
3-16-07
PART No.
SHEET
BPJR_X
1
OF
SERIES
1
REV
B
很抱歉,暂时无法提供与“BPJR04AUX”相匹配的价格&库存,您可以联系我们找货
