SJ1-42535TS-SMT-TR
SJ1-42535TS-SMT-TR
    CUIDEVICES
    CONN AUDIO JACK 4COND 2.5MM SMD
SJ1-42535TS-SMT-TR 数据手册
Additional Resources: Product Page date 08/18/2022 page 1 of 4 SERIES: SJ1-4253X-SMT | DESCRIPTION: AUDIO JACK FEATURES • low profile design • switch options include: – no switch – tip switch – ring switch – tip and ring switch PART NUMBER KEY SJ1 - 4253 X - SMT - TR Base Number Notes: Switch Options 4 = no switch 5TS = tip switch 5RS* = ring switch 6 = tip and ring switch Packaging: TR = Tape & Reel *Discontinued model SJ1-42535RS-SMT-TR SPECIFICATIONS parameter conditions/description min rated input voltage typ max 12 rated input current contact resistance1 between terminal and mating plug between terminal in a closed circuit insulation resistance at 500 Vdc voltage withstand for 1 minute Vdc 1 A 50 30 mΩ mΩ 500 Vac kg 100 MΩ insertion/withdrawal force 0.3 3 operating temperature -25 85 life at a rate of 24 cycles/minute flammability rating UL94V-0 RoHS yes Note: 5,000 1. When measured at a current of less than 100 mA/1 kHz 2. All specifications measured at 10~35°C, humidity at 45~85%, under standard atmospheric pressure, unless otherwise noted. cuidevices.com units °C cycles Additional Resources: Product Page CUI DEVICES | SERIES: SJ1-4253X-SMT | DESCRIPTION: AUDIO JACK date 08/18/2022 | page 2 of 4 MECHANICAL DRAWING units: mm[inches] tolerance: X.X ±0.2 mm X.XX ±0.10 mm X.XXX ±0.050 mm PCB: ±0.05 mm MATERIAL PLATING terminal 1 copper alloy silver terminal 2 copper alloy silver terminal 3 copper alloy silver terminal 4 copper alloy silver terminal 5 brass silver terminal 6 brass silver plastic PA6T or equivalent 8.00 0.315 9.5 0.374 0.15 2.50 0.098 4.00 0.157 2.60 0.102 4.50 0.177 5.00 0.197 2.50 0.098 0.6 0.024 +0.00 -0.10 0.1 0.004 0.07 (TYP) 2.00 0.079 4.50 0.177 4.5 0.177 (2 PLCS) 0.5 0.020 (2 PLCS) 1.00 0.039 (5 PLCS) 0.5 0.020 4 2 5 6.6 0.260 0.5 1 10.4 0.409 0.5 9.6 0.378 0.5 6 3 4 1.20 0.047 (2 PLCS) 1.60 0.063 (2 PLCS) 7.0 0.276 (2 PLCS) Recommended PCB Layout Top View Model No. SJ1-42534-SMT Schematic SJ1-42535TS-SMT SJ1-42535RS-SMT 1 4 3 1 4 3 1 4 3 6 2 5 2 SJ1-42536-SMT 1 4 3 6 5 2 2 PIN 1 11 Ø 2.5 MATING PLUG sleeve sleeve sleeve sleeve 2 tip tip tip tip 3 ring 1 ring 1 ring 1 ring 1 4 ring 2 ring 2 ring 2 ring 2 5 NP tip switch NP tip switch 6 NP NP ring switch ring switch cuidevices.com Additional Resources: Product Page CUI DEVICES | SERIES: SJ1-4253X-SMT | DESCRIPTION: AUDIO JACK date 08/18/2022 | page 3 of 4 SOLDERABILITY parameter conditions/description reel storage at relative humidity
SJ1-42535TS-SMT-TR 价格&库存
很抱歉,暂时无法提供与“SJ1-42535TS-SMT-TR”相匹配的价格&库存,您可以联系我们找货
