Additional Resources:
Product Page
3D Model
PCB Footprint
date
08/18/2022
page 1 of 4
SERIES: SJ2-2510X-SMT | DESCRIPTION: AUDIO JACK
FEATURES
• right angle
• low profile design
• reflow solder compatible
• surface mount
PART NUMBER KEY
SJ2 - 2510 X X - SMT - TR
Base Number
Notes:
# Conductors:
2=2
3=3
Switch Options:
A* = no switch
B*= tip switch
Package Style:
SMT = surface mount
Packaging:
TR = Tape & Reel
*Discontinued models SJ2-25103B-SMT-TR & SJ2-25102A-SMT-TR
SPECIFICATIONS
parameter
conditions/description
min
rated input voltage
typ
max
12
rated input current
contact resistance1
between terminal and mating plug
between terminal in a closed circuit
insulation resistance
at 500 Vdc
voltage withstand
for 1 minute
Vdc
1
A
50
30
mΩ
mΩ
500
Vac
kg
100
MΩ
insertion/withdrawal force
0.3
3
operating temperature
-25
85
life
at a rate of 24 cycles/minute
flammability rating
UL94V-0
RoHS
yes
Note:
5,000
1. When measured at a current of less than 100 mA/1 kHz
2. All specifications measured at 10~35°C, humidity at 45~85%, under standard atmospheric pressure, unless otherwise noted.
cuidevices.com
units
°C
cycles
Product Page
3D Model
PCB Footprint
CUI DEVICES | SERIES: SJ2-2510X-SMT | DESCRIPTION: AUDIO JACK
date 08/18/2022 | page 2 of 4
MECHANICAL DRAWING
units: mm
tolerance:
X.X ±0.2 mm
X.XX ±0.10 mm
X.XXX ±0.050 mm
PCB: ±0.05 mm
MATERIAL
PLATING
terminal 1
copper alloy
silver
terminal 2
copper alloy
silver
terminal 3
copper alloy
silver
terminal 10
copper alloy
silver
plastic
PA10T
Recommended PCB Layout
Top View
1
3
2
11
Ø2.5 MATING PLUG
Model No.
SJ2-25102A-SMT
SJ2-25102B-SMT
1
1
2
10
2
Schematic
SJ2-25103A-SMT
SJ2-25103B-SMT
1
3
1
3
2
10
2
PIN
1
sleeve
sleeve
sleeve
sleeve
2
tip
tip
tip
tip
3
NP
NP
ring
ring
10
NP
tip switch
NP
tip switch
cuidevices.com
Product Page
3D Model
PCB Footprint
date 08/18/2022 | page 3 of 4
SOLDERABILITY
parameter
reel storage
at relative humidity
很抱歉,暂时无法提供与“SJ2-25103A-SMT-TR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 74+9.68040
- 370+8.69596
- 国内价格 香港价格
- 1000+11.224661000+1.43969
- 2000+10.689112000+1.37100
- 3000+10.387883000+1.33236
- 5000+10.020485000+1.28524
- 7000+9.785667000+1.25512
- 国内价格 香港价格
- 1+18.303081+2.34757
- 10+15.5426610+1.99352
- 25+14.5629325+1.86786
- 50+13.8682250+1.77875
- 100+13.20591100+1.69380
- 250+12.37823250+1.58764
- 500+11.78712500+1.51183
